7 members (texas46, Stovebolt48, Uncles51, Donf, spanky, Hotrod Lincoln, Southerntruck),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,022 Posts1,055,384 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 19 Apprentice | | Apprentice Joined: Feb 2006 Posts: 19 | Just wondering if any of you Big Bolters have any detailed schematics or pictures of a dump body used in the mid 40's ? I have a 45 2 ton Chev short wheel base, that was originally a dump truck, and now a flat bed.I'm going to do a body off restoration on it this winter and I would like to put a dump box back on it! | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Sorry I don't have any photos to send you but I can describe what you might want to do as I am very familiar with how they were built. You might want to look at the members trucks here too as I'm certain you'll find some interesting stuff.
Ok, now for the decription: 10ga mild steel troughout, i.e., floor, sides. tailgate, braces etc. 3" channel understructure for the smaller trucks like Chev & F&@ds. no more than 18" sides, 6'6" ID x 8-10' in length. Flat running boards, usually a simple tapered V brace (2) on the sides, no front post, 8" rear post with no more than 6" (4") higher front & rear over sides. 2" bang board extension pocket and one horizontal tailgate brace, fairly small in cross-section, skip welds throughout and light duty hardware. Underbody direct lift or twin arm hoist usually with cast arms, hinges, links, etc. Manifold mount pump direct to cylinder base with PTO driveline. Twin floor mounted cab levers for PTO and valve. Small narrow cab shield usually about 12-15" over roof. There are still plenty of old hoists around that might be made operational with patience. The body can be built by you or a fabricator. It is all pretty straight-forward. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | | | | | | Joined: Aug 2005 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 73 | My dump body is on a 38,there's pics in the sig and I could send you more if you need them. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Great!. Both are excellent examples of what This guy is looking for.
As for "who bought slag"? Exactly, what was it used for anyway? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | exactly? considering the other things the trucker advertized, the slag refered to was being sold as an amendment for concrete, replacing part of the portland cement - gives increased hardness and durability - also, used as RR track ballast and as rip-rap on steep shore slopes to retard erosion, not to mention it's fertilizer value due to mineral content Bill | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Hmmm, quite a useful substance then I suppose. So why don't I hear about it being sold today? Inquiring minds want to know. | | | | | Joined: Feb 2006 Posts: 19 Apprentice | | Apprentice Joined: Feb 2006 Posts: 19 | Thanks guys! Does anyone out there know where there is a used pto and hydraulics in north east U.S. or central east Canada? | | | | | Joined: Dec 2005 Posts: 66 New Guy | | New Guy Joined: Dec 2005 Posts: 66 | I've got a dump body (see gallery...the red one) I want to trade for a stake bed, I suppose distance is the killer, though. Two 2t. '48 Chev. dumps. | | | | | Joined: Jun 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 23 | stonecutter49, I have a '41 with I believe the exact same bed on it, the low sides and all. The cab protector is awesome looking, do you believe that is original? I wanted to make one for mine other than what was on it and I like that one alot. Could you send me a couple detailed pics of that, like the mounting and bracing. Also, this whole posting has been quite informative for me as I have just begun to dig into restoring mine, thank you all! | | | | | Joined: Jun 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 23 | Forgot to include my email. [email protected] Thanks! | | | | | Joined: Jun 2006 Posts: 110 Member | | Member Joined: Jun 2006 Posts: 110 | I have a complete '38 Heil dumper set up in as used condition. Transportation is the challenge....
Jim
Good luck with your project!
| | | | | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | I just posted a reply in another thread and included this link which I'd forgotten shows the dump body up on my 46 2 ton. Don't know if it gives you any ideas but maybe! http://www.geocities.com/jarge46/46_Chev.html Cheers, George | | | | | Joined: Aug 2005 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 73 | R&G,I'm not sure if the cab protector came with that or not.My guess would be that it did.The construction on it seems to be quite a bit cruder then the body.I'll see what I can dig up for pics,it's apart right now and it's a bear to move around.I'll put any pics of interest up of the dump later tonight,I've been disasembling it the last month so I have a few good ones.It's an interesting setup,nothing like the modern dumps. | | | | | Joined: Aug 2005 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 73 | I updated my album with a dump body folder.There' pics there that give the general look of how it goes togeather. | | |
