2 members (Guitplayer, 1 invisible), 174 guests, and 3 robots.
Topics128,196
Posts1,057,395
Members48,469
My 1954 Suburban Carryall has 4 big bolts holding the rear body to the frame.
On my Suburban, there are no pads or blocks between the frame and the rear body/floor.
My Suburban sits lower in the the rear than in the front.
I am guessing that originally there were wood-blocks and/or pads?
I will check the Factory Assembly Manual (if I can find it), but does anyone know if there were 4 mounting-pads and/or 4 wood-blocks under 1954 Suburbans (and, probably Panel) floors?
Maybe 47-55st Advance-Design rear body-mounts were the same?
Curmudgeon
Curmudgeon
Bondo Artiste
Bondo Artiste
Ha! Buoymaker, you linked Tim's own reference page for body mounts.
Tim I can check mine tonight.
~ Phillip
Curmudgeon
Curmudgeon
Suburban Carryall
Carryall Suburban
Carryall
Suburban
Phillip please add pictures of your vehicle for comparison.
Thanks, Phillip. That body-mount reference-page is (as you know) for front body mounts.
Buoymaker, I am looking for info on where the 4 large rear body-mount bolts go through the frame rail.
Maybe I will try wood blocks (and rubber pads) the same dimensions as used on the front?
