| | | Forums66 Topics128,188 Posts1,057,331 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | My 1954 Suburban Carryall has 4 big bolts holding the rear body to the frame.
On my Suburban, there are no pads or blocks between the frame and the rear body/floor.
My Suburban sits lower in the the rear than in the front. I am guessing that originally there were wood-blocks and/or pads?
I will check the Factory Assembly Manual (if I can find it), but does anyone know if there were 4 mounting-pads and/or 4 wood-blocks under 1954 Suburbans (and, probably Panel) floors?
Maybe 47-55st Advance-Design rear body-mounts were the same? | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 |
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | Ha! Buoymaker, you linked Tim's own reference page for body mounts.
Tim I can check mine tonight.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | Suburban Carryall Carryall Suburban Carryall Suburban Phillip please add pictures of your vehicle for comparison.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Ha! Buoymaker, you linked Tim's own reference page for body mounts.
Tim I can check mine tonight. Thanks, Phillip. That body-mount reference-page is (as you know) for front body mounts. Buoymaker, I am looking for info on where the 4 large rear body-mount bolts go through the frame rail. Maybe I will try wood blocks (and rubber pads) the same dimensions as used on the front? | | |
