0 members (),
182
Mod | | | Forums66 Topics128,284 Posts1,058,523 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2022 Posts: 10 'Bolter | | 'Bolter Joined: Jul 2022 Posts: 10 | My old gauge pod has idiot lights. I have an original pod with gauges, but I tore up he dash getting it out. Any tricks out there on how to replace the pod? Chevy,1966 C20 | | | | | Joined: Jul 2000 Posts: 2,213 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,213 | I did this on a 1971 Camaro. The original cluster had a huge gas gauge, no tach and idiot lights; pretty sad for an SS model! I found a cluster out of a wreck with tach, oil pressure, small gas gauge and a tach. It also had a clock. The tach replaced the huge gas gauge and the gas gauge moved off to the corner. I had to buy new senders for water temp and oil pressure. The senders replaced the switches. Worked fine. Interesting video for you: www.youtube.com/watch?v=CkRAGtNdPCs
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | You might look at Ronfrancis wire works.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Dec 2019 Posts: 451 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 451 | I know the '63 is a bit different but my c-10 had the full instrumentation including the factory tach. I've seen many with the idiot lights but if you search they are out there. many of the c60's had the upgrades panel and it swaps out. Our '66 grain truck did, though it didnt have the tach, just a blank in that spot. Original always looks better than aftermarket hodge podge if available.
Larry Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY. If you are missing one component, you'll need an abundance of the others two.
