1 members (GMCJammer51), 69 guests, and 5 robots.
Topics128,180
Posts1,057,149
Members48,464
Hi everyone; My front wheel bearings are in great shape and are the OLD style, looks like musket balls in there, Can I drive 55-60 down the road with these type bearings?? headscratch ohwell
'38 1.5ton; "The stuff is as tough as woodpecker lips"
Yes you can. Make sure you grease them well. Ball bearing type have been around forever and are reliable if maintained properly.
38 1.5 ton On your bearings when you adjust feel your hub for heat after driving a little should be barely warm . Caught a rear one too tight that way,if they heat may become a vicious cycle and kill your bearing ! I like to feel the drums and hubs to see if they are all working and know they are not too tight.
Will do. thumbs_up
