| | | Forums66 Topics128,151 Posts1,057,004 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2020 Posts: 366 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 366 | Hi everyone; My front wheel bearings are in great shape and are the OLD style, looks like musket balls in there, Can I drive 55-60 down the road with these type bearings??
'38 1.5ton; "The stuff is as tough as woodpecker lips"
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Yes you can. Make sure you grease them well. Ball bearing type have been around forever and are reliable if maintained properly.
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | 38 1.5 ton On your bearings when you adjust feel your hub for heat after driving a little should be barely warm . Caught a rear one too tight that way,if they heat may become a vicious cycle and kill your bearing ! I like to feel the drums and hubs to see if they are all working and know they are not too tight. | | | | | Joined: Nov 2020 Posts: 366 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 366 | Will do.
