| | | Forums66 Topics128,010 Posts1,055,303 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Had a pull tractor head needing work that has 300#'s of valve seat pressure. Our hand spring compressor does not have the needed leverage and our air spring compressor didn't have enough grunt with the shops 150# line pressure. Solution was to fab a line from the nitrogen bottle we use to fill race car tires. The pressure was set at 150#s to start on each valve spring and then raised till retainer cleared keepers, <>340 #s. One does not START at 340 as this will knock head off bench. Moderator may move to Hipo or Tools. Did have to replace black O-rings in spring compressor with green high pressure ones used in a-c systems. May come in handy for someone and if not file it in your dictionary of useless facts.
Evan
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Where there's a will (along with a bit of knowledge) there's a way. I would never had thought to use a commercial bottle of compressed gas.
| | | | | Joined: Nov 2004 Posts: 2,399 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,399 | Gotta love creative problem solving.  John
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | If you work with your hands long enough most of use have had to fashion a custom tool for a specific job. You have to be a great problem solver to get the job done. In regards to bottle gas, years ago when I was a telephone cable splicer we hauled around bottles of nitrogen to power our air wrenches. You could crank them up pretty high. Probably high enough to bust the air line if we weren't careful. We also periodical had to watch safety videos about how they could be turned into missiles.
| | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | I've also cobbled up special tooling to use a hydraulic press for those "maximum grunt" jobs, mostly for getting a grip on rifle barrels when removing them from the receiver during a barrel change. With enough force and leverage, something's gonna give! The tightest barrels I've encountered are on Weatherby Vanguard rifles. On occasion, I've had to make a plunge cut with a lathe cutoff tool just ahead of the receiver to relieve the pressure on the barrel threads. Jerry
