| | | Forums66 Topics128,004 Posts1,055,265 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 23 | I want to upgrade tie rod ends and steering arm on '48 2 ton. What part number should I seek out? Would I be better off to just change out the spindle and the whole works at the king pin, thereby upgrading the brakes to bendix? What would I be looking for in that case? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy dazysnow, I would look for a whole front axle assembly from the same size truck but 53 or newer, that way you could checkout/rebuild the whole thing and then install it. You should also look for the newer pitman arm from the steering box so you can use all the newer style tierod/draglink ends, hope that helps. | | |
