6 members (Lostbuthaulinass, Peggy M, Joe H, 50Chevy3100, Shardean, 1 invisible), 86 guests, and 2 robots.
Topics128,057
Posts1,055,815
#1474042 11/05/2022 8:55 PM
Donald S.
Donald S.
I have a 1953 Chevy truck. I know it has a 1956 235 6 cylinder with 3speed on the column. My question is I don’t know which transmission I have Muncie or Saginaw. It still has the torque tube rear end. I have a picture of the numbers but they don’t seem to match what the specifications say ? My 3 rd gear synchronizer is getting bad. It was ok before I took the trans out for restoration but now it grinds some in only 3rd. I had an old timer trans guy look at it before I put it back in and he said it was good. I see a part for them on chevys of the 40 but I’m not sure it is the right one? Help?
Synchronizer
Transmission numbers
1949 Chevy Carry All
Follow the resto in the Project Journals
1953 Chevy 5-window
"Frame off Restoration"
Follow the resto in the DITY
Beginning to End Slideshow
More images in Flickr
\|/\|/ Dual Ex. \|/\|/Dynamat
Please don't tell my wife how much this thing cost!
Check your PM.
Mike
1951 3100 5 window
What type of transmission lube did you put in?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Donald S.
Donald S.
Mike B smile
Mike,
When I initially put the truck together I just used some 90 wt gear oil but I read on here to use Travellers 90 wt mineral oil so have since changed it but it’s no different.
1953 Chevy 5-window
Insomniac
Insomniac
Looks to me that transmission is the original to the truck. Cast # 591615 is listed here at the top of the page:
http://chevy.oldcarmanualproject.com/parts/1929_54/260.htm
This may be a useful read: https://chev235guy.blogspot.com/search/label/Fixing%202nd%20and%203rd%20gear%20clash
Link from here: https://www.stovebolt.com/ubbthread...oper-sm318-syncro-rings.html#Post1182444
Gord 🇨🇦
1954 1/2 ton 235 4 speed
