3 members (Southerntruck, Hanks custodian, Goach2), 110 guests, and 3 robots.
Topics128,193
Posts1,057,253
Members48,466
I'm having a tough time finding the outer wheel bearing seals for Cloey (42 1.5 ton 4x4). VOV has the inner but the outers are a dead end. Any leads out there? Thank you!
Dale in Iowa,
Although I can't supply part numbers, I will say that all seals can be matched by ID, OD, thickness and lip configuration.
If you have a Motion Industries, Dixie Bearing, Applied Industrial or some other bearing house near you, you can match and order generic seals.
Stuart
Thank you! I think I've located the correct seals through Chevy of the 40s. www.chevsofthe40s.com
These guys seem to have good numbers and lots of parts. I may still be in trouble for the rear seals and will certainly let you know.
Dale
Dale;
check my post on your axle question, I gave you a lead for the rear seal, it is unique to the Banjo axle
John Gott
1942 G5106 1.5-ton Chevy cargo dump Gallery page
Old Dominion Stovebolt Society
T/Sgt. Gott (28 years of service with the USPP)
1940 Chevy G506 4112 cargo dump
1942 Diamond T G509 969A 4 ton wrecker
1942 Ward LaFrance G116 series 2 10 ton wrecker
1944 Ward LaFrance G116 series 5 10 ton wrecker
1931 Ford AA with a WEAVER crane
1944 Sterling HC 165 tractor
1944 Autocar U7144T w/ 10 ton trailer
it is pressed into the outer bearing adjustment nut, when you get the new seal, just pry it out and use a large socket to "push" the new one into teh nut
John Gott
