| | | Forums66 Topics128,179 Posts1,057,134 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 39 Member | | Member Joined: Jun 2006 Posts: 39 | I'm having a tough time finding the outer wheel bearing seals for Cloey (42 1.5 ton 4x4). VOV has the inner but the outers are a dead end. Any leads out there? Thank you! | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Dale in Iowa,
Although I can't supply part numbers, I will say that all seals can be matched by ID, OD, thickness and lip configuration.
If you have a Motion Industries, Dixie Bearing, Applied Industrial or some other bearing house near you, you can match and order generic seals.
Stuart | | | | | Joined: Jun 2006 Posts: 39 Member | | Member Joined: Jun 2006 Posts: 39 | Thank you! I think I've located the correct seals through Chevy of the 40s. www.chevsofthe40s.com These guys seem to have good numbers and lots of parts. I may still be in trouble for the rear seals and will certainly let you know. Dale | | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | Dale; check my post on your axle question, I gave you a lead for the rear seal, it is unique to the Banjo axle
John Gott 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
| | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | it is pressed into the outer bearing adjustment nut, when you get the new seal, just pry it out and use a large socket to "push" the new one into teh nut
