5 members (Otto Skorzeny, Woogeroo, klhansen, 2-Ton, TUTS 59), 77 guests, and 6 robots.
Topics128,193
Posts1,057,241
Members48,465
Fellow bolters....
When driving my GMC 3 ton, I get a small grind before it will go into gear. I took it to my garage and adjusted the clutch and it was ok but the longer I drive the worse the grind gets and it will not down shift no matter what I do except come to a complete stop before shifting.
Now I haven't driven a manual since I was 14 on the farm, but none of what is happening seems normal to me.
I call around for parts and everyone can get parts but they want numbers....can I get some help with clutch, rearend, tranny parts?? I need axle seals and noone can find a number unless I pull them apart and take them out.
Matt
\'47 GMC 1 1/2 ton, "Bertha"
1942 Chevy 2-Ton Truck, "Helga"
There is a fine line between "hobby" and "mental illness."
I just need help with make and model then people can find the numbers and cross them to get the proper part.
You may need to learn the fine art of double clutching.
To up-shift--step on clutch, shift to neutral, let up the clutch, then step on it again, and shift to the next gear.
To downshift--step on clutch, shift to neutral, let off the clutch and rev the engine, step on clutch, and shift to the lower gear.
It takes practice, but as you get used to your truck and how it acts, you'll be able to run through the gears without making a sound.
Good luck!!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
3B Offline
Hy naddaclue, what you are describing sounds more like a transmission problem than a clutch one to me. You said you can't downshift no matter what, not even when you double clutch? As for the parts ask us for numbers for specific parts, hopefully we can help.
3B,
I don't see where he said even double clutching won't help on the downshifts. This transmission appears to be the "crash box" which would require the dance described by Rich. smile
Stuart
I did the double clutch and a few times triple clutched it....I just about had the pedal through the floor board. The mechanic that worked on it had the same problems, the more the truck was driven the worse it got. He seems to think that the pressure plate was getting hot and not allowing a disengage.
as far as parts go...I need to be able to find the make and model of my axle. Make and model of my tranny. I don't even know where to look.
naddaclue,
Would it be possible to pull the flywheel cover, crawl under the truck with a good trouble light and with the help of a friend, work the clutch and see what might develop.
Stuart
Does the clutch slip?
You might try NAPA for seals, but if you're going to tear it down anyway, you can get the numbers off the old ones. There are co's on the web that specialize in bearings and seals.
Matt,
That transmission does not have syncro's, you must double clutch and when up shifting take your time. go slower than normal to change gears.
When down shifting you must double clutch, put in neutral, let out clutch and rev up engine then push in clutch and change to next lower gear. This will take practice, this is not like a modern truck. I dout that you need a clutch, just practice.
agree with the others double clutching requires rpm trans speed and road speed all to be coordinated just takes practice. And each truck will have slightly different sweet spots as well. Bertha will have her own personality
