7 members (Joe H, jaycoop, 2-Ton, 42465967, Southerntruck, Shade Baby, TUTS 59),
125
Mod | | | Forums66 Topics128,129 Posts1,056,362 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 39 Member | | Member Joined: Jun 2006 Posts: 39 | Can someone explain the difference between the terms banjo and split-axles?. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Dale in Iowa,
I always thought the old Ford rear ends that had the bolt on axle tubes were called "banjo" rear ends. I don't think I have heard the term split-axle other than maybe a reference to a two-speed rear end.
Stuart | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | my understanding: banjo axle assembly = a final drive assembly [differential pumpkin] that assembles into a housing [carrier] and is bolted into place split axle is the standard modern design of separate shafts for each wheel run by a differential, allowing different rotational speeds around corners most truck are banjo design where the entire pumpkin can be removed from the "banjo" axle houseing - most cars are not - both split style Bill | | | | | Joined: Jun 2006 Posts: 39 Member | | Member Joined: Jun 2006 Posts: 39 | These terms are used when researching parts (seals bearings) for the big 1940s Military GMC and Chevy trucks. | | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | Dale; Your Chevy has BANJO axles. BANJO axles were manufactured by GM, SPILT axles were manufactured by TIMKEN. The majority of CCKW's have SPLIT axles. DUKW's all had BANJO axles.The "split" term refers to the pumpkin section of the axle in which the 2 halves are bolted togather. With over 550,000 CCKW's made during the war, GM could not produce enough axles. The only intechangable parts I believe are the brake shoes for the rear axle. All Banjo parts are interchangleable between CHEVY and GMC trucks. However the front rear drive axle has differant lenght axle shafts from a Chevy axle because of the offset of the pumpkin, the rear drive axle shafts are the same as a Chevy. You may want to check out cckw.org. as this site is geared more towards your truck. I currently own a 1941 Chevy 1 1/2 ton cargo dump and I am just wrapping up a 2 year frame off restoration.
John Gott 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
| | | | | Joined: Jun 2006 Posts: 39 Member | | Member Joined: Jun 2006 Posts: 39 | John:
Thank you VERY much. I'm having one heck of a time finding the correct outer seals for both front and back wheel bearings (to keep the shoes from becoming satuarated). Why are their inner seals on these axles if the wheel bearing lubed from the differential?
Any leads to seals would be greatly appreciated. VOV numbers are dead ends.
Dale | | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | Dale; VOV has an aftermarket part number for the inner seals, I believe it is either a NAPA or CR number, check his website under the PARTS section or CHEVY SPECIFICATIONS, Bob Muller is a very good person to deal with, his number is 518-872-1002. For the outer seals, contact Rex Ward DUKW parts, www.dukwparts.com. He is located in England. The bearings are NOT lubed by gear oil, you will have some seepage of gear oil, but they are lubed with bearing grease, if your steering knuckles are full of muck (combo of gear oil and grease) then your inner seal in the axle tube needs attention. Also I would suggest getting a TM (technical manual) for your truck, VOV has them for sale. good luck John Gott 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
| | | | | Joined: Jun 2006 Posts: 39 Member | | Member Joined: Jun 2006 Posts: 39 | John: Can I contact you directly please? Dale 319-895-0506 [email protected] | | |
