1 members (Gray_Ghost), 104 guests, and 4 robots.
Topics128,164
Posts1,056,967
Members48,458
Met a guy yesterday at our local Farmers Market who has a '54 3100. One of his many questions to me was, what prevents the gas station's fuel pump from shutting off when it reaches full. Since I've haven't had such a problem, that I rememberblush,,, I told him I would ask the experts. Any idea?
Craig
On these old rig the a big ail bubble will form at the top of the tank / filler neck, pump doesn't see pressure to shut off. Slowing down flow will help. Had a small tube attached to the top of the tank, going up to top of the filler neck. Allows air to to escape. Still need to slow flow down towards full but helps.
BC
1960 C60 pasture art
Never rely on the automatic shutoff when filling antique cars. You shouldn't do it with modern cars, either since sometimes the latch mechanism sticks.
Even old cars with vent tubes in the filler neck can't always shut down fast enough as the fuel in most pumps comes out extremely fast and overcomes the vent.
1950 Chevrolet 3100 (Ol' Roy)
I put my ear as close as I can to the filler neck and wait for the glug-glug. Did that just this morning. Before automatic shutoffs, that's the way it was done.
Oh yes, the glug-glug method.
Craig
Yep, I’ve even stopped for a moment to let noisy traffic go past so I could continue to listen for the glue. Plus watch the gallons on the pump to guess when it’s getting close.
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
Leo Offline
Moderator
Moderator
My 1953 panel, with the filler neck down low, was hard to fill. If the right side of the vehicle was lower than the driver's side, it would hardly fill at all. So I didn't worry about the auto shutoff. It was easy to look down the filler neck and see.
The air in the tank being displaced by the gas being pumped in has to come out the filler neck on the tank on these ole rigs, modern rigs nozzle fits tighter to filler, air / fuel vapor enter the vapor (EVAP) canister, fuel vapors held.
Farmers can tell you about plugged EVAP canisters & fuel tanks sucked in.
BC
So this is why I've been doing the GLUG GLUG method for so many years. Kinda forgot why. Now I can reply to my friends inquiry. I find getting gas at COSTCO is pretty quiet as compared to a gas station on a busy street.
Craig
I had that happen one time. I didn't want to fill my tank. I got to my 5 gal, let go of the handle it kept going. should I run, squeeze the hose? then it just stopped like nothing happened. I told the people inside, they didn't seam too care much. As left I told the guy in the car behind me what happened. then left. Stan
Anybody remember those fuel tank whistles (gas alarm) ?
