5 members (55shaker, Phak1, 49fastback, Biermann, Jaison), 106 guests, and 2 robots.
Topics128,138
Posts1,056,751
Members48,454
Anyone here gave this a try? I've been researching this for a while and found Flat Out Engineering has kits for this conversion that seem well made.
Think I can get an mid-80's donor vet for a decent price as they are not very desirable, and this would give the 55 IFS front and rear, R&P steering, and really good brake system. Any pro's and con's?
If I go this route, I'd like to purchase the donor vet by the end of the year.
Pic is the frame headed to blasting, have chassis prep and paint arriving today and Monday to apply post blasting.
1955 1st Series Chevy 3100
“Three generational project”
Follow the story in the DITY
Try the HiPo Forum for modifications such as this.
I would say it is doable. Geometry would be the greatest challenge, but if you are using the entire set-up that should all be solved except for the mounting. Rear ends of those vettes were super soft. You may need to add to the mono leaf?
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
Thanks Ferris Buller (love the movie and watched it earlier this week).
The kit has to be used with coil overs or airbags at all corners, the fiberglass leaf is a no-go.
