1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#1472645 10/26/2022 8:50 PM
I am starting to reassemble my 47 chevy truck. I remembered seeing a diagram of the firewall and where everything was located. I can't seem to locate that diagram again. Can someone help by telling me where I might find where all where all the hoses and wires go?
1947 3600 Chevy
AD Addict & Tinkerer
This is from the ‘54 Factory Assembly Manual.
Phil
Project Journals
Stovebolt Gallery Forum
Thanks, that will help. My truck is a little different. I'm not going to have vacuum wipers, or the original 6 volt system, so no need for a regulator. I'll need speedometer cable, choke cable, and wiring harness with fuse block mounted where the original was. I just want it to look and function well.
1947 3600 Chevy
Curmudgeon
Curmudgeon
A "slamming" website did a hatchet job on this cab removal (attached pictures) but there is enough remaining to give you a clue.
Also Step 5
http://devestechnet.com/Home/ADWiringSystem
The regulator wiring can be removed but the regulator itself can remain to cover the holes in the firewall. Also there is a battery connection that may be useful. Some alternators have a "sense" connection that can be used to compensate for voltage drop.
Thanks, very helpful website.
1947 3600 Chevy
