7 members (klhansen, edgardo, Hanks custodian, TexasJim50, stlcardinalsguy, Woodcmiami, 1 invisible), 57 guests, and 2 robots.
Topics128,059
Posts1,055,820
#1472637 10/26/2022 7:23 PM
Here is another attempt on posting pictures. This is my 1954 6400 Dad bought new. He used it farming here in s calif. The truck hauled a lot of hay, and Dsd did disking for others hauling his Allis Chalmere Model M tractor and disk. I continued his
disking work for others making fire brakes, before the fire season started. The truck had a probably three motors, and a bunch of tires in over 100k miles of hard going. It had a hard life, and is retired now. Still have the truck and it has been in a garage all its life. Stan
Authorized Pest
Authorized Pest
Opps. Try again Stan.
(Just to let you know, Stan got one picture posted in the Welcome Centre for the Big Bolt. I suggested he get on board in the Big Bolts so you fellas can help him out if he needs it. ~ Peg)
~ Peggy M
1949 Chevrolet 3804
#1472643 10/26/2022 8:31 PM
And again my 54 6400
stans6400 #1472644 10/26/2022 8:41 PM
Big Bolt Forum Moderator
that is a good looking truck, and a great history!
Mike
stans6400 #1473400 11/01/2022 2:16 AM
Nice truck. A 6400 series truck is a 16000lb. gvw, 2 ton truck, and not a 1 1/2 ton. 1 1/2 ton 14000lb. gvw trucks that wheelbase are 4400 series trucks.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
stans6400 #1473436 11/01/2022 1:37 PM
Crusing in the Passing Lane
Front hub cover clearly shows as 2 ton, 1.5 ton cover smaller, cast with pipe thread. 2 ton allows use of ‘91 to ‘01 disc brake spindles and hubs on early hub with factory wheel bolt pattern.
Ed
stans6400 #1473535 11/02/2022 1:06 AM
stans6400
In 1970 I worked with a lead body man. a dent like that would come in in the morning, by evening he would have it in primer, no fill of any kind, just straighten it. Once painted, you couldn't tell it had been hit. Most lead work would be joints and not much in there really.
spanky #1474202 11/06/2022 10:28 PM
stans6400 #1474203 11/06/2022 10:30 PM
Thanks, for the information on the weight. Stan
