Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (carbking, Shade Baby), 106 guests, and 3 robots.
Topics128,281
Posts1,058,471
Members48,490
Glad to finally be a member on this site. I've had my 1949 3100 for about five years now and I don't know what I would of done with out this site.
A little background, I was born and raised in North Central Illinois, about 1.5 hours south west of Chicago out in the middle of the corn and bean fields. I am 27 years old and bought my truck when I was 22 and have been slowly plugging away at it since. It's an all original 1949 Chevy 3100 with a running stock 216. Here's a list of things that I have done so far.
- removed body
- removed drivetrain
- repaired a few small bends in the frame
- needle scaled, primed and painted frame (brush paint rustoleum gloss black)
- all new huck brakes
- all new stainless brake lines
- new coker white walls
- new to me maroon steel wheels (came from a farmer off an old implement, beautiful patina)
- new king pins
- new tapered bearings
- LMC Truck 3" lowering springs all around with new bushings
- new gaskets on engine covers
- new aluminum radiator and hoses
- new spark plugs, coil and cables
- fully rebuilt carb
- flushed out the cooling jackets
- painted engine with dark gray engine enamel
- rebuilt u-joint
At this point, I had the drivetrain all reassembled and had the engine popping on gas in the carb. So I was confident it would run and I switched my focus to the body. It was extremely rotted but I'm a sucker for the patina and I was going to do everything I could to preserve the look.
I realized the cab was a little too far gone for my experience in sheet metal so I sold it. I bought another cab that was in a little better shape. I am still kicking myself for this. I ended up doing just as much work on the new cab than I would of on the original.
Being young and dumb, I bought the "better" cab without knowing enough of what to look for. Someone had done a total botch job on the floor repair using a combination of mastic and pop rivets and me, none the wiser, fell for it. I tore into the "better" cab and replaced all this.
- New front cab mounts
- New inner and out cowls
- New front floor pan
- New kick plates
- New cab corners
This is where I stand currently with the project. I am 95% done with the sheet metal work. I took the cab to be sandblasted to bare metal (there were six different colors of paint, the outermost being blue).
I'm still unsure of my path forward on the paint. I love the patina on the bed and front end but probably can't match it enough to make it look good. More to come on that.
I've had the engine running for 15+ minutes on a mocked one gallon tank and it runs great.
Working on some plans for home made bed wood. Probably going to cut down some marine grade plywood and use some tung oil on it and fasten it down with elevator bolts. I'm not going for the show truck look, just a good running, mostly original truck to get people's attention.
Anyways, I just wanted to introduce myself on here and hopefully get some replies/opinions from some of you all.
I've attached a few pictures to give you guys an idea what I'm working with. Looking forward to having conversations on the forums!
Welcome to the 'bolt. Thanks for the pix and the status of your project!
Another quality post.
Real Trucks Rattle
Authorized Pest
Authorized Pest
I think the Stovebolt Collective will be please to see a "young fella" is among us! thumbs_up Welcome! wave
Seems you have already got a good deal going on.
You may have already figured out a few things about our virtual garage. Maybe this will help, tho:
THE SHOPS - General Truck Talk. The Engine Shop. Driveline. The Electrical Bay. The Radio Bench. The HiPo Shop. Paint and Body Shop. Interiors. The Tool Chest. Making a Stovebolt Bed. Name that Part. "Technical knowledge sharing" when you are ready to break out the tools and get to work. Plenty of space and tools available -- just find your way to the appropriate shop and get to work.
The Swap Meet. Trucks for Sale. Trucks Wanted. Truck Parts for Sale. Truck Parts Wanted. Misc. Stovebolt Stuff. Modern GM and Non-GM. Freebies. Stovebolt Spotting Alert Network. Hauling Board. eBay and Craigslist Links. FREE - what more need we say!
And I see you already found the Great Lake Bolters and said your hellos! thumbs_up
You've figured out how to do images, but if you have questions about IT things here, THE OFFICE. has the Shortbus to help.
See you around ...
wave
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
Us older fellas are jealous of that clean uncluttered garage! Mine was that way for about 2 months.. not anymore!
Real Trucks Rattle
Welcome thad!!! wave
Your truck and shop both look great. thumbs_up
You've got an awesome start on your project and look forward to seeing and hearing more.
Looking forward to seeing future posts in the various forums. grin
~ Dan
1951 Chevy 3 window 3100
Moderated by  J Lucas
