8 members (Hotrod Lincoln, tclederman, 2-Ton, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom),
167
0
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 123 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 123 | I'm looking at an auction site for some donor vehicles that have better front end sheet metal and doors than I have on my truck. I know the doors should fit ok, but I am wondering about the two outer front fenders. Should the fenders from the vehicles listed below fit my truck? They look visually the same.
My Truck -1956 Chevy 6100 - VIN - 6A56F
Donor Trucks -1957 Chevy 6400 - VIN V6B56K - I assume from the vin this is 1956 not a 1957 as listed on the site. -1956 Chevy 4400 - VIN P255K - I assume this is actually a 1955 2nd series not a 1956 as listed on the site. -1956 Chevy 6400 - VIN 6B57K - I assume this is actually a 1957 not a 1956 as listed on the site | | | | | Joined: Jul 2018 Posts: 238 Rustbucket Ranch | | Rustbucket Ranch Joined: Jul 2018 Posts: 238 | The fenders should be identical (other than emblem mounting holes) as well as the doors. | | | | | Joined: Feb 2016 Posts: 1,987 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,987 | Hey Doug, maybe we can get together on one of your finds, I'm looking for a 2 speed axle for my '57 and we could salvage parts and split some costs.
| | | | | Joined: Nov 1995 Posts: 5,720 62401 | | 62401 Joined: Nov 1995 Posts: 5,720 | If you guys work a deal on one or more of these trucks to split up parts, please circle back and let us know -- that kind of coordination and parts sharing is what I always aimed for with the site and it would be gratifying to know.
Thanks, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2016 Posts: 1,987 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,987 | OK John, will do. I hope Doug finds what he needs and we can get together on the rest. We're probably only 30 miles from each other.
| | | | | Joined: Nov 2009 Posts: 123 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 123 | Buckshot, I will get ahold of you if i do get one of these. They will probably go cheap at the auction. Biggest expense is going to be shipping.
Will also give the bolters here first shot. | | | | | Joined: Feb 2016 Posts: 1,987 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,987 | Are you looking out of state? If it's close I could probably get a trailer.
| | | | | Joined: Nov 2009 Posts: 123 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 123 | These are all in Nebraska. Their stuff doesn't rust away | | | | | Joined: Feb 2016 Posts: 1,987 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,987 | OK then, keep me in the loop.
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I'm looking at an auction site for some donor vehicles that have better front end sheet metal and doors than I have on my truck. I know the doors should fit ok, but I am wondering about the two outer front fenders. Should the fenders from the vehicles listed below fit my truck? They look visually the same.
Donor Trucks -1957 Chevy 6400 - VIN V6B56K - I assume from the vin this is 1956 not a 1957 as listed on the site. -1956 Chevy 4400 - VIN P255K - I assume this is actually a 1955 2nd series not a 1956 as listed on the site. -1956 Chevy 6400 - VIN 6B57K - I assume this is actually a 1957 not a 1956 as listed on the site Your front fenders are the same as the 1955-2 fenders except for the emblem holes (the '55 has 3 holes and the '56 has 4 holes) and can be found on the 4000 and 6000 Series trucks. The 1957 4000 and 6000 Series truck fenders are a one year only fender as the front axle was moved 2.5" forward to help eliminate tire rub on the cab during a turn, so be careful when looking at fenders when they are laying on the ground. The bottom of the wheel opening on the 55/56 fender is about 39" wide and the 57 is about 41" wide. Mike B  | | | | | Joined: Nov 2009 Posts: 123 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 123 | Thanks for the information. I think I know which one I will go after. Fingers crossed | | |
