1 members (J Lucas), 40 guests, and 4 robots.
Topics128,014
Posts1,055,324
Members48,419
#147199 06/17/2006 11:05 AM
will this engine swap work
The truck is a 1953, I believe, a 6600 series - 1 1/2 ton. It has a 4 speed tranny
with a 2 speed rear and the 235 engine (6 cylinder).
i would like to replace it with the engine from a 1968 Chevy and it has a 292 Chevy truck engine (6 cylinder). It also has a 4
speed tranny with a 2 speed rear. I do not know its series #.
#147200 06/17/2006 12:49 PM
Mike,
You might want call Tom Langdon and discuss this. He has a 292 into a 1954 and earlier chassis. It's not clear in the listing if this is for car or truck (and no info on size of truck, if that matters).
Tim
Tim
#147201 06/17/2006 12:49 PM
Your '53 6000 series truck is a 2-ton, not a 1-1/2. Not that its matters to your question.
Will it work? Sure. Will it be a lot of work? Probably.
The two motors mount quite a bit differently, so you'll have to frabricate some mounts.
The 292 will not mate to your existing bellhousing and the bellhousing from the '68 will not bolt to the bellhousing crossmember in the '53.
And you'll have clutch linkage issues and things like that to deal with.
It can be done, and its probably a pretty good swap, but its not just a bolt together thing, you'll have some adapting and fabricating to do.
#147202 06/17/2006 7:06 PM
Hey Mike, when did you get a Chevy. Would have to be a 6400, or 6500, if it's a 6000 series truck. That would make it a 2 ton. I've got a fresh rebuilt 261 performance short block, out in the shop, that would be a better mate, for this truck.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#147203 06/18/2006 12:46 PM
Bond Villain
Bond Villain
Man, Spanky, I can't believe no one has snapped that engine up yet. I called my engine guy about my 235 (he's had it about a year) and if he hadn't started it yet, I was going to tell him not to bother and then talk Peggy into a trip to NC to grab that 261.
Unfortunately, Billy said "It's done!"
Will the 235 "848" head go on a 261?
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
#147204 06/18/2006 7:36 PM
thanks everyone, for the replies. spanky, i posted this for a friend. the truck that he has is a dump truck. there is nothing wrong with the engine in this truck. he just has this other engine available and was wondering if it would just bolt in and work.
