5 members (NJC, cmayna, dt235sd, Hotrod Lincoln, lumbersawyer), 105 guests, and 5 robots.
Topics128,064
Posts1,055,860
Members48,428
I'm looking at an auction site for some donor vehicles that have better front end sheet metal and doors than I have on my truck. I know the doors should fit ok, but I am wondering about the two outer front fenders. Should the fenders from the vehicles listed below fit my truck? They look visually the same.
My Truck
-1956 Chevy 6100 - VIN - 6A56F
Donor Trucks
-1957 Chevy 6400 - VIN V6B56K - I assume from the vin this is 1956 not a 1957 as listed on the site.
-1956 Chevy 4400 - VIN P255K - I assume this is actually a 1955 2nd series not a 1956 as listed on the site.
-1956 Chevy 6400 - VIN 6B57K - I assume this is actually a 1957 not a 1956 as listed on the site
Rustbucket Ranch
Rustbucket Ranch
The fenders should be identical (other than emblem mounting holes) as well as the doors.
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 - in the DITY Gallery - (Dad's truck)
1955 Chevy 6500 - in Big Bolts - (Possible parts truck?)
1958 Chevy 3800 w/9 ft bed - in Project Journals - (Current project)
1959 Chevy Spartan 10400 - in Big Bolts
7
7 Offline
Hey Doug, maybe we can get together on one of your finds, I'm looking for a 2 speed axle for my '57 and we could salvage parts and split some costs.
62401
If you guys work a deal on one or more of these trucks to split up parts, please circle back and let us know -- that kind of coordination and parts sharing is what I always aimed for with the site and it would be gratifying to know.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
7
7 Offline
OK John, will do. I hope Doug finds what he needs and we can get together on the rest. We're probably only 30 miles from each other.
Buckshot, I will get ahold of you if i do get one of these. They will probably go cheap at the auction. Biggest expense is going to be shipping.
Will also give the bolters here first shot.
7
7 Offline
Are you looking out of state? If it's close I could probably get a trailer.
These are all in Nebraska. Their stuff doesn't rust away
7
7 Offline
OK then, keep me in the loop.
My Truck
Donor Trucks
Your front fenders are the same as the 1955-2 fenders except for the emblem holes (the '55 has 3 holes and the '56 has 4 holes) and can be found on the 4000 and 6000 Series trucks.
The 1957 4000 and 6000 Series truck fenders are a one year only fender as the front axle was moved 2.5" forward to help eliminate tire rub on the cab during a turn, so be careful when looking at fenders when they are laying on the ground. The bottom of the wheel opening on the 55/56 fender is about 39" wide and the 57 is about 41" wide.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks for the information. I think I know which one I will go after. Fingers crossed
