2 members (Rnl364, baldeagle),
53
Mod | | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 36 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 36 | My 1950 GMC, model 253 with 228 engine and 6 volt system. Voltage regulator was not working so I replaced it this morning with a new standard VR -18 regulator, now it shows a large discharge when the key is turned off. And yes I polarized it. The old regulator was not charging the battery ( generator putting out 7 volts but from regulator to battery was .5 volts) and showed a small amount of discharge when key was on and no discharge showing when key was off. Is VR-18 the wrong regulator? And if so what would be the correct one? Or did I do something to cause this? | | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | A large discharge in the "key off" position is caused by stuck cutout relay points. Disconnect a battery cable RIGHT NOW, or the battery will discharge itself through the generator and burn both units out. Your "new" regulator is defective and needs to be replaced. A 1/2 volt drop between the regulator BAT terminal and the battery indicates there's a dirty connection somewhere- - - - -at an ammeter connection, or possibly at the battery cable connection at the starter. You should be getting approximately 7.5 volts, measured at the battery posts (not the cable terminals) with the engine running at a fast idle with a fully charged battery if the regulator is adjusted properly. Jerry
