4 members (Bill Hanlon, Hotrod Lincoln, crenwelge, 78buckshot), 73 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#1471674 10/19/2022 5:05 PM
I'm tired of buying Batteries, I buy Interstate and they don't last 2 years. This one only made 20 months, is this normal.
H Online: Content
How often does the battery get "cycled "- - - -partially discharged and then recharged? A battery that sits around, even on a "tender" won't last anywhere near as long as one that gets cycled periodically. Turn the headlights on for a couple of hours, then either drive a few miles or use a medium-rate charger overnight to bring it back to full charge. I've got batteries that have been in service for 5 years or more, but they get exercised regularly. 6 or 12 volts doesn't really matter- - - -the kind of use a battery gets definitely does.
Curmudgeon
Curmudgeon
1955 1st 6 volts and still working. Mine came with the truck I purchased in 2017. A generic FLAPS battery.
Do a web search for Interstate battery failures.
Typically batteries have a one year or more warranty.
Battery manufacturers hope that customers do not save their purchase receipts or proof of purchase.
Take it back to the place you purchased from and fuss.
The first battery I had in it lasted about 5 years. I start it and let run to charge at least once a week . I've never put a battery tender on it. I noticed the warranty on the Interstate battery was only 6 months. I just got a Duracell battery from Batteries and Bulbs and it has a year warranty and is made in USA and cheaper. The wait for a Interstate battery was going to be 3 weeks. This tells me it must be coming from China! Big companies just can't resist $$$ they make from buying from the Chinese!
My 6v Optima gel (AGM) battery has been reliable since 2007.
Same price at Walmart - free shipping and no core charge.
I use 2-gauge battery cables (and 2 gauge body ground straps/cables).
I sometimes do not start-up and run my 6v 1954 Suburban for over a year.
The engine starts up quickly.
My bigger concern is fuel in the carburetor (after sitting a long time). So far, not problems there.
WOW! I have the wide braded ground and 1 gauge positive cable. I'll have too check into that if this battery doesn't last!
I've bought 2 battery's since 2002 from Advance Auto. Second one still working. Sometimes drive every week, sometimes not driven for 2 months. Never had a battery tender on it.
Harold Wilson
41 Chevy 3/4 Ton
7
7 Online: Content
I still have 6 volt in my 1955 IH 300U, battery is about 7 years old and still going, Napa brand. Tractor will sit for 2 - 3 weeks sometimes.
The Duralast battery i had in my 2005 chevy pickup gave up the ghost after 9 years!
Another quality post.
Real Trucks Rattle
