1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | I'm tired of buying Batteries, I buy Interstate and they don't last 2 years. This one only made 20 months, is this normal. | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | How often does the battery get "cycled "- - - -partially discharged and then recharged? A battery that sits around, even on a "tender" won't last anywhere near as long as one that gets cycled periodically. Turn the headlights on for a couple of hours, then either drive a few miles or use a medium-rate charger overnight to bring it back to full charge. I've got batteries that have been in service for 5 years or more, but they get exercised regularly. 6 or 12 volts doesn't really matter- - - -the kind of use a battery gets definitely does. Jerry
| | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | 1955 1st 6 volts and still working. Mine came with the truck I purchased in 2017. A generic FLAPS battery.
Do a web search for Interstate battery failures. Typically batteries have a one year or more warranty. Battery manufacturers hope that customers do not save their purchase receipts or proof of purchase. Take it back to the place you purchased from and fuss.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | The first battery I had in it lasted about 5 years. I start it and let run to charge at least once a week . I've never put a battery tender on it. I noticed the warranty on the Interstate battery was only 6 months. I just got a Duracell battery from Batteries and Bulbs and it has a year warranty and is made in USA and cheaper. The wait for a Interstate battery was going to be 3 weeks. This tells me it must be coming from China! Big companies just can't resist $$$ they make from buying from the Chinese! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | My 6v Optima gel (AGM) battery has been reliable since 2007. Same price at Walmart - free shipping and no core charge. I use 2-gauge battery cables (and 2 gauge body ground straps/cables). I sometimes do not start-up and run my 6v 1954 Suburban for over a year. The engine starts up quickly. My bigger concern is fuel in the carburetor (after sitting a long time). So far, not problems there. | | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | WOW! I have the wide braded ground and 1 gauge positive cable. I'll have too check into that if this battery doesn't last! | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I've bought 2 battery's since 2002 from Advance Auto. Second one still working. Sometimes drive every week, sometimes not driven for 2 months. Never had a battery tender on it.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Feb 2016 Posts: 1,987 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,987 | I still have 6 volt in my 1955 IH 300U, battery is about 7 years old and still going, Napa brand. Tractor will sit for 2 - 3 weeks sometimes.
| | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | The Duralast battery i had in my 2005 chevy pickup gave up the ghost after 9 years!
