1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#1470193 10/08/2022 3:51 PM
I recently acquired a used Chev 235 truck engine. It came with transmission, clutch, generator, starter and manifolds with carburetor, but all the 'accessories' were removed and in boxes. I was told it ran well when pulled. It's been sitting around for several years in a dry barn. At least all the openings were well sealed up and nothing was seized.
It took a while to get it assembled enough for a test run. It ran OK without any major internal engine noise. A compression test showed one cylinder had 75PSI, but the others were in the 135 range. Off came the head to identify a burnt exhaust valve in cylinder 1. The rest of the exhaust valves need a re-grind. The intakes looked perfect.
We pulled the oil pan off for a quick check. Bearings looked perfect. Maybe 0.040 undersize on the mains.
Then the surprises kept coming. Oil pump tube fittings were finger tight. Flywheel bolts were not tight. Camshaft gear was not pressed in tight and there was 1/8" endplay.
Pistons were 0.040" oversize. Some have some mild surface erosion due to pre-ignition? But the rings seemed to have about 0.050" end gap. We're guessing it has 0.030" oversize rings in a 0.040" oversize bore ?
So, it needs new rings and a valve job.
Lately it seems that parts are getting harder to find.
Any suggestions on brands or quality of Piston Rings and Valve seats and guides?
John.
When God gives any man wealth and possessions, and enables him to enjoy them, to accept his lot and be happy in his work�this is a gift of God. He seldom reflects on the days of his life, because God keeps him occupied with gladness of heart. Ecclesiastes 5:19-20
John D #1470196 10/08/2022 4:11 PM
Egge Machine
1950 Chevrolet 3100 (Ol' Roy)
Never heard of Egge Machine - what is that ?
1960 C20 Platform
John D #1470963 10/13/2022 4:55 PM
One of the largest engine parts retailers in the US. Google them.
John D #1470966 10/13/2022 5:09 PM
H Online: Content
Egge uses the Jesse James business model. The only difference is that Jesse had to use a gun to rob people. On any particular day on Ebay, I can buy a truckload of new 235 parts, at very reasonable, or downright cheap prices. That goes for pistons, rings, bearings, gaskets, valves, and even crankshafts, cams, and connecting rods. The resto-ripoff places like to claim that stovebolt stuff is scarce and gold plated- - - - -not so by a long shot! If you're not willing to do a little internet shopping, there's always Rock Auto- - - -good brand name parts at fairly reasonable prices! Now, for scarce, custom made stuff like GMC pistons, you might have to bite the bullet and pay Egge's prices, but not so for regular stovebolt rebuilding parts!
What's wrong with a .050" ring end gap? When the rings heat up to normal operating temperature and expand, the gap will be virtually zero, and at 2K RPM they're only having to seal compression and combustion pressure for 1/60 of a second at a time. Measure the pistons and/or the bore size with an accurate inside micrometer, and order the proper size rings to fit.
John D #1470969 10/13/2022 5:30 PM
Rock Auto. Nice new pistons rings, Sealed Power, $45.00
https://www.rockauto.com/en/catalog/chevrolet,1957,bel+air,3.8l+235cid+l6,1326147,engine,piston+ring,5640
I am with Jerry on this. I ordered a set of GMC 302 rod bearings from Egge a while back because they said they had them in stock. The bearings arrived and had been coated in a like black graphite coating. When I looked at the bearings closely, they were all the same size but from three different manufacturers and the bearings that came from similar manufacturers were from different lots. It was a put together set. I did not pay a premium for a put together set. I then proceded to wipe the bearings with lacquer thinner and low and behold, these were some messed up bearings with nicks, gouges, and corrosion that had been dressed with scotch brite and coated. What horse pucky. Worse, they would not take them back and refund my money. Never again.
Mike
John D #1471073 10/14/2022 3:04 PM
Second ebay or Rock Auto. If must use a specialty supplier go with Terrill Machine out of DeLeon, Texas. as they just rob you rather than rob AND rape you like EGGE.
Evan
Hahaha! True.
