1 members (Bill Hanlon),
156
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 69 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 69 | I recently acquired a used Chev 235 truck engine. It came with transmission, clutch, generator, starter and manifolds with carburetor, but all the 'accessories' were removed and in boxes. I was told it ran well when pulled. It's been sitting around for several years in a dry barn. At least all the openings were well sealed up and nothing was seized.
It took a while to get it assembled enough for a test run. It ran OK without any major internal engine noise. A compression test showed one cylinder had 75PSI, but the others were in the 135 range. Off came the head to identify a burnt exhaust valve in cylinder 1. The rest of the exhaust valves need a re-grind. The intakes looked perfect.
We pulled the oil pan off for a quick check. Bearings looked perfect. Maybe 0.040 undersize on the mains.
Then the surprises kept coming. Oil pump tube fittings were finger tight. Flywheel bolts were not tight. Camshaft gear was not pressed in tight and there was 1/8" endplay. Pistons were 0.040" oversize. Some have some mild surface erosion due to pre-ignition? But the rings seemed to have about 0.050" end gap. We're guessing it has 0.030" oversize rings in a 0.040" oversize bore ?
So, it needs new rings and a valve job.
Lately it seems that parts are getting harder to find.
Any suggestions on brands or quality of Piston Rings and Valve seats and guides?
John.
When God gives any man wealth and possessions, and enables him to enjoy them, to accept his lot and be happy in his work�this is a gift of God. He seldom reflects on the days of his life, because God keeps him occupied with gladness of heart. Ecclesiastes 5:19-20 | | | | | Joined: Oct 2021 Posts: 6,722 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,722 |
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Nov 2016 Posts: 57 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 57 | Never heard of Egge Machine - what is that ?
1960 C20 Platform
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | One of the largest engine parts retailers in the US. Google them.
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Egge uses the Jesse James business model. The only difference is that Jesse had to use a gun to rob people. On any particular day on Ebay, I can buy a truckload of new 235 parts, at very reasonable, or downright cheap prices. That goes for pistons, rings, bearings, gaskets, valves, and even crankshafts, cams, and connecting rods. The resto-ripoff places like to claim that stovebolt stuff is scarce and gold plated- - - - -not so by a long shot! If you're not willing to do a little internet shopping, there's always Rock Auto- - - -good brand name parts at fairly reasonable prices! Now, for scarce, custom made stuff like GMC pistons, you might have to bite the bullet and pay Egge's prices, but not so for regular stovebolt rebuilding parts!
What's wrong with a .050" ring end gap? When the rings heat up to normal operating temperature and expand, the gap will be virtually zero, and at 2K RPM they're only having to seal compression and combustion pressure for 1/60 of a second at a time. Measure the pistons and/or the bore size with an accurate inside micrometer, and order the proper size rings to fit. Jerry
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Rock Auto. Nice new pistons rings, Sealed Power, $45.00
https://www.rockauto.com/en/catalog/chevrolet,1957,bel+air,3.8l+235cid+l6,1326147,engine,piston+ring,5640
I am with Jerry on this. I ordered a set of GMC 302 rod bearings from Egge a while back because they said they had them in stock. The bearings arrived and had been coated in a like black graphite coating. When I looked at the bearings closely, they were all the same size but from three different manufacturers and the bearings that came from similar manufacturers were from different lots. It was a put together set. I did not pay a premium for a put together set. I then proceded to wipe the bearings with lacquer thinner and low and behold, these were some messed up bearings with nicks, gouges, and corrosion that had been dressed with scotch brite and coated. What horse pucky. Worse, they would not take them back and refund my money. Never again.
Mike
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Second ebay or Rock Auto. If must use a specialty supplier go with Terrill Machine out of DeLeon, Texas. as they just rob you rather than rob AND rape you like EGGE.
Evan
| | | | | Joined: Oct 2021 Posts: 6,722 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,722 | Second ebay or Rock Auto. If must use a specialty supplier go with Terrill Machine out of DeLeon, Texas. as they just rob you rather than rob AND rape you like EGGE. Hahaha! True.
