4 members (dunfire, John Dlugos, Gdads51, Greg_H), 69 guests, and 8 robots.
Topics128,187
Posts1,057,211
Members48,465
Had earlier post about my oil filter cannister but have been unable to locate the spring that attaches to the bolt that holds the lid on and applies pressure on the oil filter. Any help would be appreciated on finding the correct spring or one close to the size I need. The spring is conical in shape at 1 1/2" in length with the wire size about 1/16", top of the spring at 5/8" inside diameter and the base at 1 " inside diameter.
spring and bolt
1950 Chevy 3100 PU all stock
Curtis Lee,
Just a suggestion, but may be put an ad for what you are looking for here: Truck Parts Wanted ?
Could be someone has got a spare laying around that can help you out. Am sure others with knowledge of what the part number is (if one exists) or a direct source (if available) will chime in as they can.
Good luck! thumbs_up
NOTE: This may need to be moved to The Engine Shop for better on-topic conversation.
~ Dan
1951 Chevy 3 window 3100
Curmudgeon
Curmudgeon
Do you have any old junkyards in MO? This is where I would go.
We have several here in NC but I'm not risking a snake bite for parts I don't need.
You can also try searching ebay.
https://www.ebay.com/itm/392972309769
Curtis Lee,
You can also reach out to fellow 'Bolter "KCMongo" by PM, or go to his website here: Mongos Garage
He is a long time 'Bolter and has an awesome shop and lots of resources/parts. Plus his shop is any easy drive for you. thumbs_up
Let us know how your quest works out. wave
~ Dan
Thanks I'll be seeing him.
I look but I seem to always have trouble seeing let alone finding. Thanks!
Thanks, I'll be checking this out.
Curtis Lee Check your farm store,mine has a lot of springs pretty sure they have conical too.
Any compression spring close to the correct diameter and length can be converted to a conical shape with a pair of channellock pliers in a matter of minutes. All it needs to do is hold the element down toward the bottom of the canister. The O rings at the top and the bottom of the canister do the sealing so the oil gets forced through the filter media.
It’s a pretty stout spring. I don’t think it really needs to be conical as long as it fits up into the “peak” of the filter lid properly.
1951 3100
