Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (Guitplayer, KEVINSKI, SmalltownTRKGuy, Otto Skorzeny, UnclePaddy, TGP), 134 guests, and 6 robots.
Topics128,281
Posts1,058,461
Members48,490
#147076 09/15/2006 4:17 PM
I've got the 3 peice wheels. Made the mistake of taking wheel apart before breaking the bead loose. I don't want to bend the small section prying on it. Saw sawzall suggested a while back what type blade would work best? wood blade seems to clog fast
#147077 09/15/2006 4:41 PM
I am not up on the split rim wheels, but if it were mine I would go find an old truck stop and have the tires removed and then reinstalled after I reconditioned the rims. As I remember those wheels were called widow makers and if not properly handled could cause you severe injury. Be carefull and good luck.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#147078 09/15/2006 4:58 PM
kb3csw,
Sometimes you can lay the wheel down and actually drive over it slowly with another vehicle...do this as close to the bead as you can.
Stuart
#147079 09/15/2006 5:02 PM
Toyvo these are the 3 piece not the split. They have the main part of the wheel then a outer ring and a lock ring to hold outer ring in place. Both this style and the 2 piece widowmakers were available in 54 (according to shop manuael) no idea why they used both types. I proably will take the rest to a tire shop and have them break the bead if nothing else so thats a good suggestion. with only the outer ring left to the tire there is no support to hold the tire firm while trying to get outer ring off without bending it
#147080 09/15/2006 5:10 PM
Thanks Atomarc may try that if tire shop gets scared of the others. next time though I will break both sides loose then take the wheel apart.
#147081 09/15/2006 7:50 PM
found the answer even the old nylon tires have a steel cord round the bead so metal blade was needed. learn a little each day.
#147082 09/16/2006 7:18 PM
Before you put them together be sure that all the seating surfaces are clean and free from rust. A wire brush on an angle grinder works best. The safest way to air them up (if you don't have a cage) is to wrap them at 3 points with a chain, snugly but not tightly, and stand clear while they're airing up. Hands-free chuck is a must.
1951 3800
-hotshoe
#147083 09/16/2006 11:25 PM
Thanks for the advice hotshoe36. on my 38 when i remounted them I bolted them on the truck and used a truck tire inflater on opposite side from lock ring in case it blew off. your method leaves less to chance
#147084 09/19/2006 1:13 AM
I used to work at a old shop years back, the old timer who owned the place would put the tire under the hoist arms,air it up with the rings off and pour coca cola around it.go to the office and wait.BANG! it worked but dangerous!I dont think I'd do that anymore myself.
#147085 09/21/2006 10:56 PM
ok I'm missing something at what point did he put rings on and what purpose did the coke serve? carbination some how forceing ring in place?
#147086 09/23/2006 3:34 AM
Tire cage was the best investment I have made, the chain method works too, but believe me, if a ring blows off, even if your not hurt, it will make the "outrageous" prices of the tire shop seem very "reasonable"!
Insert clever statement here:
