BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,780 Posts1,039,294 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Dec 2013 Posts: 25 'Bolter | 'Bolter Joined: Dec 2013 Posts: 25 | I tried to do a series of searches but didn't seem to find anything that applied. I was sure that there had to be several discussions on whether to coat the head gasket with anything before install, but didn't see any.
So, I'm asking about all the possible coatings that would be appropriate for a rebuild on a 235 58-62. I have a Felpro head gasket set. I know many prefer the "Best" gaskets, but this is what I have now to work with.
Thanks for help and advise.
Life is good on Windy Ridge!
| | | | Joined: Jun 2021 Posts: 157 'Bolter | 'Bolter Joined: Jun 2021 Posts: 157 | I use Permatex 80697 Copper Spray-A-Gasket since years. Works fine so far - but actually, the gaskets without the copper spray didn't show any problems ether. Not sure if it really makes a differece, maybe just peace of mind. | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It depends on the type of gasket you are using. Its best to check with the manufacture. They often specify on the package when you should not use sealer. Felpro are good gaskets. They generally don't require or recommend any sealer. Copper coat in the spray & RTV are good products.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | Joined: May 2015 Posts: 9,830 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 9,830 | If you need some assistance keeping the gasket in place during assembly, then a little stickum is fine. Otherwise, not really necessary.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | Joined: Dec 2017 Posts: 1,609 'Bolter | 'Bolter Joined: Dec 2017 Posts: 1,609 | I have used copper coat spray (although early on it was a brush on) for a couple of decades with the Felpro copper head gaskets. Two years ago I replaced the head on my 261 and decided that even though I still had a couple of copper gaskets in my stash, I wanted to use a fresh gasket and ordered the Felpro blue composite gasket. I did use the copper spray a gasket primarily because I have never had any gasket failures so why mess with success.
Mike
| | | | Joined: Dec 2008 Posts: 1,915 'Bolter | 'Bolter Joined: Dec 2008 Posts: 1,915 | Include (compressed) head gasket thickness in "factors that effect choice". This affects piston to head, and intake valve to piston clearance. Most engine could use thinner gaskets to close up the quench distance. | | | | Joined: Dec 2013 Posts: 25 'Bolter | 'Bolter Joined: Dec 2013 Posts: 25 | Thanks for all the replies!! We'll see how it turns out soon. Jay
| | | | Joined: Feb 2004 Posts: 28,674 Kettle Custodian (pot stirrer) | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 28,674 | I've been using Permatex Super 300 brush-on liquid sealer for over 60 years. It was developed to seal aviation gasoline, and I've never seen an application it didn't work well on. It's also more economical, and a LOT less messy than spray-on sealers. Super 300 is almost black, NOT the 3-D brown brush on liquid. Jerry
