3 members (60steve, sron48, dt235sd), 173 guests, and 5 robots.
Topics128,204
Posts1,057,288
Members48,467
Hi All,
They side toward and away from the truck. What is the fix for this? I cant tell what it needs.. the bolts attaching the boards to the frame appear to be tight.. headscratch
p.s. obviously getting this thing going! Hope to meet some of you at the events. wave
'38 1.5ton; "The stuff is as tough as woodpecker lips"
If your bolts are tight, the boards will not move. Check the bolts to see that the nuts are not bottoming out on the threads before they tighten. Should be carriage bolts, if I recall. Maybe some extra washers will help.
Mike
1936 1-1/2 Ton (RD) Stake Body Original
Okay will try!
381.5ton Use bigger washers may need 2or 3 to absorb the hight of the square on your carriage bolts.
