| | | Forums66 Topics128,204 Posts1,057,288 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2020 Posts: 366 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 366 | Hi All, They side toward and away from the truck. What is the fix for this? I cant tell what it needs.. the bolts attaching the boards to the frame appear to be tight..  p.s. obviously getting this thing going! Hope to meet some of you at the events.
'38 1.5ton; "The stuff is as tough as woodpecker lips"
| | | | | Joined: May 2009 Posts: 135 'Bolter | | 'Bolter Joined: May 2009 Posts: 135 | If your bolts are tight, the boards will not move. Check the bolts to see that the nuts are not bottoming out on the threads before they tighten. Should be carriage bolts, if I recall. Maybe some extra washers will help.
Mike | | | | | Joined: Nov 2020 Posts: 366 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 366 |
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | 381.5ton Use bigger washers may need 2or 3 to absorb the hight of the square on your carriage bolts. | | |
