I'm close to installing the rear fenders having just completed restoring the running board aprons and looking for advice / tips on installing the fender welt. Besides test fitting, marking where the holes will be and pie cutting for the bends are there other tips that I should know?
Ron - - Dusty53 1954 Chevy 3604 In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel."
Good idea! Your comment on no welting from the factory caused me to revisit my disassembly photos and righto, no welting or anti-squeak . I wont be installing the welting.
Just a comment...which really only matters if you use your truck as transportation...this stuff harbors water and moisture like a demon and if you're in a place where it rains / is very humid most of the year, you might not like the rust bubbling that trapped moisture can encourage. The capillary action from the underside is also pretty bad in my experience. If your truck stays in the garage most of the time, I don't suppose it is any problem. A friend in high school put this stuff on his 51 and also had the dealership undercoat all the fenders after that. It was a wetter than usual summer and by October he had to take all that off, repair the rust and repaint. Every single bolt in the bed had a bull's-eye of rust around it.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
