3 members (Otto Skorzeny, moparguy, DaveV), 112 guests, and 1 robot.
Topics128,111
Posts1,056,244
Members48,437
I'm close to installing the rear fenders having just completed restoring the running board aprons and looking for advice / tips on installing the fender welt. Besides test fitting, marking where the holes will be and pie cutting for the bends are there other tips that I should know?
Ron - - Dusty53
1954 Chevy 3604
Insomniac
Insomniac
I used spray adhesive to hold it in place while installing the bolts through the box sides. I put the glue on the fender flange.
BTW, the welt is optional. They didn't come from the factory with it. But I like the look.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Good idea! Your comment on no welting from the factory caused me to revisit my disassembly photos and righto, no welting or anti-squeak . I wont be installing the welting.
Ron - - Dusty53
1954 Chevy 3604
Agreed. My welting is a darker color and will match the interior color which will match the lettering in tailgate. I am anxiously waiting assembly.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
Moderator, Electrical Bay
Just a comment...which really only matters if you use your truck as transportation...this stuff harbors water and moisture like a demon and if you're in a place where it rains / is very humid most of the year, you might not like the rust bubbling that trapped moisture can encourage. The capillary action from the underside is also pretty bad in my experience. If your truck stays in the garage most of the time, I don't suppose it is any problem. A friend in high school put this stuff on his 51 and also had the dealership undercoat all the fenders after that. It was a wetter than usual summer and by October he had to take all that off, repair the rust and repaint. Every single bolt in the bed had a bull's-eye of rust around it.
~ Jon
