1 members (baldeagle),
26
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | In a couple weeks I'm going to collect my newly purchased '52 COE. Since its a little wide for my trailer I'm planning to pull the outside duals off.
But I don't know what size lug wrench I need to get the nuts off, and its a couple hundred miles away, so I can't just check before making the trip.
What size wrench do I need?
And will the inside wheels stay on when I pull the outsides off? They are held on by some inner nuts aren't they?
Its been more than 25 years since I pulled the rear wheels off one of these things...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I forgot what size for sure but I think 1⅛ or 1 1/16. You'll have to put the nuts back on the inners. I've hauled 'em that way myself.
Tip: If it has no engine and a heavy steel bed consider putting it on the trailer rear first. Puts more weight on the tongue or gooseneck. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Steve, These Chevy COE's I have sitting around here take a 15/16 socket, for the wheel lug nuts, front, & rear. Out in the field, I usually take a 15/16 deep well impact socket, 6"in. extension, & a pull bar, for leverage. | | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | All of my big trucks use the 15/16 too, Scott | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | Yes the 15/16" is the correct one, however when I went to the parts store and got new ones, they were 1 1/16". I'd take everything that kills with you. I hate it when I'm out on the road and dont have the right stuff> | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Thanks guys.
I'll take all my big impact stuff, and a long cheater bar...
I'm sure I remember working on something that also had inner nuts of some sort, but I don't recall what it was.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | take w-d and a propane torch to | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | as soon as you get there spray the lugs with pb blaster. | | | | | Joined: Dec 2004 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 60 | Old sub,
The 15/16" nuts have fine thread and a 5/8 size hole. Just a little more info if you have to replace a nut or two! Congrats and Have fun with it. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Thanks guys for all the help. My original plan was to get the COE this weekend, but things aren't working out as planned. It will be a couple more weeks before I can make the trip.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2004 Posts: 6 Junior Member | | Junior Member Joined: Sep 2004 Posts: 6 | I would use Kroil spray first. Big cheater bar and take an extra breaker bar (you may break the frist one..sorry for the pun. Also take a punch and hand sledge to "tap" the lug nut out of the socket when it finally comes off the stud. good luck, Masterlynk | | |
