4 members (UtahYork, 3B, dt235sd, Shardean), 118 guests, and 2 robots.
Topics128,031
Posts1,055,433
Members48,422
#146998 05/25/2006 4:44 AM
In a couple weeks I'm going to collect my newly purchased '52 COE. Since its a little wide for my trailer I'm planning to pull the outside duals off.
But I don't know what size lug wrench I need to get the nuts off, and its a couple hundred miles away, so I can't just check before making the trip.
What size wrench do I need?
And will the inside wheels stay on when I pull the outsides off? They are held on by some inner nuts aren't they?
Its been more than 25 years since I pulled the rear wheels off one of these things...
#146999 05/25/2006 5:39 AM
I forgot what size for sure but I think 1⅛ or 1 1/16. You'll have to put the nuts back on the inners. I've hauled 'em that way myself.
Tip: If it has no engine and a heavy steel bed consider putting it on the trailer rear first. Puts more weight on the tongue or gooseneck.
#147000 05/25/2006 2:39 PM
Steve, These Chevy COE's I have sitting around here take a 15/16 socket, for the wheel lug nuts, front, & rear. Out in the field, I usually take a 15/16 deep well impact socket, 6"in. extension, & a pull bar, for leverage.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#147001 05/25/2006 3:22 PM
All of my big trucks use the 15/16 too,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
#147002 05/26/2006 12:54 AM
I
I Offline
Yes the 15/16" is the correct one, however when I went to the parts store and got new ones, they were 1 1/16". I'd take everything that kills with you. I hate it when I'm out on the road and dont have the right stuff>
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#147003 05/26/2006 2:07 AM
Thanks guys.
I'll take all my big impact stuff, and a long cheater bar...
I'm sure I remember working on something that also had inner nuts of some sort, but I don't recall what it was.
#147004 05/26/2006 3:22 AM
take w-d and a propane torch to
#147005 05/27/2006 1:22 AM
Z
Z Offline
as soon as you get there spray the lugs with pb blaster.
#147006 06/02/2006 10:36 PM
U
U Offline
Old sub,
The 15/16" nuts have fine thread and a 5/8 size hole. Just a little more info if you have to replace a nut or two! Congrats and Have fun with it.
#147007 06/03/2006 3:23 AM
Thanks guys for all the help. My original plan was to get the COE this weekend, but things aren't working out as planned. It will be a couple more weeks before I can make the trip.
#147008 06/09/2006 4:29 AM
Junior Member
Junior Member
I would use Kroil spray first. Big cheater bar and take an extra breaker bar (you may break the frist one..sorry for the pun. Also take a punch and hand sledge to "tap" the lug nut out of the socket when it finally comes off the stud. good luck,
Masterlynk
