Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (cmayna, EddieD, 2 invisible), 47 guests, and 3 robots.
Topics128,009
Posts1,055,291
Members48,419
#1469652 10/05/2022 4:43 AM
Needing ideas on how to attach bolt threads in the door jamb for hinge mounting. Only missing 1, fortunately.
1952 GMC
Starting with a basket case
In the Project Journals
1967 GTO
1967 Firebird
Fox Offline
If it were me:
1. Cut a little plate the size of the indent behind the hole. Drill it to size. You might have to monkey it up in there. I think I remember the top part of the pocket not having a full plate above it, so there is a chance of access.
2. Weld the proper size nut on that plate’s backside. I believe it’s 3/8” fine thread (correct me if I’m wrong, all).
3. Drill 3 plug weld holes on the cab pillar around the hole opening.
4. Plug weld the little plate with the nut in place.
If you’re in primer, you’ll burn a little primer, but sand it out, reapply, and sand the repair smooth.
If that doesn’t work, I’d cut the face of it out, weld a nut in and weld it back up, steel work it, and reprime.
Or…
Oversized drill the hole so the nut fits inside the hole and weld it in. Good penetration will be key and difficult to do because of welding on the wrong side, different thickness of metals, etc.
Anyone else?
Occam’s razor, anyone? Simpler ideas?
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Panel adhesive like they glue Ford trucks together with?
1950 Chevrolet 3100 (Ol' Roy)
Just curious…
Assume we didn’t want “perfection” to be the enemy of “good” or that a simple non-welding solution was preferred, would this be a suitable application for a rivet nut?
I’ve never used them, but this is the precise problem for which they’re advertised.
That looks like the best solution so far.
Rivet nuts are good, but you'd need to dimple the hole back a bit to allow for the flange on the face of the rivet nut so the hinge would fit flush as intended.
If the threads are clean and the bolt screws in easily, gluing the nut on the back side would work, as it just needs to be restricted from turning till it gets tight enough for friction to hold it. Although I think access to that top hole is blocked by the box around the hinge pocket. That points toward the rivet nut solution. The hole size might be an issue for the rivet nut, but not insurmountable, even if it's too large.
I've used rivet nuts to mount fenders to a boat trailer with a box frame side member. Worked well.
Thread size is 3/8-24 like Fox said
Thank you gentlemen for all your input. After weighing all my options, I decided to go with Mr Fox's option number one. I had to take a die grinder with a worn down wheel small enough to get it in the hinge pocket and cut a slice out of the hinge pocket a little bit of beating on metal on the inside and working it around I managed to get the nut into place and welded. Thanks again
1952 GMC
1967 GTO
1967 Firebird
Nicely done. thumbs_up
Thanks for sharing! shake
~ Dan
1951 Chevy 3 window 3100
