| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 23 Apprentice | | Apprentice Joined: Aug 2004 Posts: 23 | Anybody know where I can get a puller that will fit a 47 chevy 1 1/2 ton? The ones I have gotten at the parts store are to big. | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | You can make one using a threaded rod 1/2 dia. or larger,two nuts to fit the rod,two bolts to fit your steering wheel threads and a piece of steel with three holes drilled in it.Soak the spline on the steering wheel with Kroil or Liquid Wrench over night to help you out.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | An old boy from Tennesse taught me an old trick. You get your buddy to pull up on the wheel while you put a ball peen hammer on the shaft. Take another hammer and give it a whack and the wheel pops off. Someone yelled that hitting two hammers together is dangerous because the striking surfaces are tempered and can shatter, cause injury. He claimed that the ball end of a ball peen isn't tempered. Frankly, I wasn't sure I believed him so I just use a big brass hammer on the ball peen. Works every time!!! | | |
