4 members (50Chevy3100, Otto Skorzeny, carbking, 1 invisible), 74 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
#146977 05/23/2006 12:52 AM
Apprentice
Apprentice
Anybody know where I can get a puller that will fit a 47 chevy 1 1/2 ton? The ones I have gotten at the parts store are to big.
#146978 05/25/2006 1:48 AM
You can make one using a threaded rod 1/2 dia. or larger,two nuts to fit the rod,two bolts to fit your steering wheel threads and a piece of steel with three holes drilled in it.Soak the spline on the steering wheel with Kroil or Liquid Wrench over night to help you out.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#146979 07/23/2006 6:31 AM
An old boy from Tennesse taught me an old trick. You get your buddy to pull up on the wheel while you put a ball peen hammer on the shaft. Take another hammer and give it a whack and the wheel pops off. Someone yelled that hitting two hammers together is dangerous because the striking surfaces are tempered and can shatter, cause injury. He claimed that the ball end of a ball peen isn't tempered. Frankly, I wasn't sure I believed him so I just use a big brass hammer on the ball peen. Works every time!!!
