Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (2-Ton, Shof, Charles in CA), 147 guests, and 3 robots.
Topics128,281
Posts1,058,487
Members48,490
#1469562 10/04/2022 9:17 PM
I have two pictures attached, I know that the front main does not have any seal, I am wondering if the grove shown in the picture requires one on the 1933 207?
Any help is much appreciated!
1933 207 stovebolt shoved into a Chevy 1/2 ton with all the 29-32 left overs. (Woody) - all original, originally old!
Courage = Being scared to death, then going to do the task anyways!
No seal there- - - -there should be a spiral groove at the back of the crankshaft that moves oil toward the crankcase. Whatever doesn't get trapped by the spiral should get thrown off by the slinger before it gets to the outside. The angled groove in the bearing also moves oil toward the crankcase.
Correct, no seal. That area collects oil that comes out of the bearing and directs it back into the pan.
My Blog
Thank you for the responses, it back together now I’m just waiting on some information on the oil pump that was in it?
If the pump was making good oil pressure, you're probably good to go. It's pretty common for the pressure to be a little high on a cold engine, and then drop pretty dramatically as the oil and the engine parts warm up to normal running temp. 5-10 PSI at hot idle isn't unusual on a spray-oiler engine, rising t0 20-25 or so at highway speed.
The bearing in your picture looks like it's contacting the crankshaft with less than 1/3 of its available area (the shiny spot). I'm not sure if the insert type bearing can be scrape-fitted for a better contact patch, but that's why I always fit Babbit rods to as big as possible of a contact area before I begin to adjust the clearance with shims.
With the shims, shims are .0014. Two reading each journal front to back.
Front .003,.002
Middle .002, .002
Rear ..002, .003
I find it a little weird that to two ends are .003?
Looks like I’m in the window! Thanks for all the help everyone!
Even a tiny bit of uneven wear on the crankshaft journal or the bearing will produce different clearance depending on where you measure. Since a strand of hair is around .0015" in diameter, it doesn't take much wear or out of round to produce some oddball clearance measurements.
Hello all, I was told by another forum that I am not supposed to shim main bearing inserts, you can see the wear marks this to me indicates a hot spot in the bearing. I shimmed it like I mentioned and the crank rotates a little easier. Now my next question? Should I go through and check all the rod caps or will the .0014 not be an issue?
