Here is an attempt to attach a picture using click/drag.
I can see a file indicated in attachment manager.
Picture does not show when selecting Preview New Thread.
Picture (along with caption I added in Blue text) displays after completing post.
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
Yes, when image files are added to a post via the Attachment Manager, they do not appear when you preview the post. They only appear when the post is actually posted. That's the nature of the beast.
BTW, your blue caption also appears at the bottom in white next to the file name when it is viewed. I would suggest using a different color that has better contrast with the photo so it will stand out and be read more easily.
This now works for the iPad too. I split the screen between photos and Stovebolt, and was able to drag and drop. So much easier that searching thru my 3,000 + photos!
Phil Moderator, The Engine Shop, Interiors and Project Journals
1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes Project Journals Stovebolt Gallery Forum
Would a cell phone be the same as an iPad? Had a new guy email me from his Samsung. Directed him here (as well as the original thread for pictures in the forums) in case he ended up with some problems.
Thanks all.
Peg
~ Peggy M 1949 Chevrolet 3804 "Charlie" - The Stovebolt Flagship In the Gallery "Success comes in 'cans' ..."
The white text displayed at the bottom when you open the attachment is actually the file name I created when editing/saving the screenshot. My oops for not noticing it was already displayed with the picture.
Was trying the blue text using picture editing program based on others comments about need for a caption, but looks like no need for the extra effort.
Thanks as well to Peggy for helping sort this stuff out and make life easier for us all.
Dan
Bolter sent an image to me in an email. I "saved as" and it went to my download folder. I didn't really want to open the file but it would not drag from the "preview pane" portion in the file manager (files in on side of screen/actual image on right side of screen). NUTS.
On a whim, I just dragged the file itself. As it rolled across my screen, once it got even NEAR the Attachment Manager box, it was the image of the image file ... and shazam! It worked.
The other day, I only got an image CLOSE to the box (ran out of mouse runway). I had to let go of mouse but the image made it to the box!
Anyone else try this?
Peg
When I first posted my "click/drag" test results, I clearly forgot to say that I was actually able to click and drag the file from my computers download directory to the Attachment Manager box successfully (was so proud of myself for being able to figure out how that I didn't actually say what I did-duh).
I did have to shrink down the web page window on my computer screen so I could actually see the file directory window and place mouse cursor over the file name to do the click/drag over to the Attachment Manager box.
Hope this clears any muddy waters I may have caused.
Dan
Thanks all.
Peg
It would be for an iPhone but I can’t say for any other brand.
I would think if the phone is able to run split screens, it should work.
Every now and then when I add an image using drag and drop, it doesn't appear on the bottom of the box. What I do is click the "X" on the box to close it and then reopen the attachment manager and the image I added shows up a few seconds later. Just a small glitch. Closing and opening the attachment manager seems to work every time when it doesn't show up normally.
In Windows, if I have everything at full screen, I can click open the attachment manager, then click on the open folder where my photos are on the task bar at the bottom, select the photo I want to attach, then hover the mouse pointer over the browser icon on the task bar, which opens it up, then drop the photo in the attachment manager box. Having things at full screen helps find the photo among the bunches that I have.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
There seem to be a number of steps for adding images. I'm still working on it myself.
Part of *my* problem is, well, when I drag an image over, it disappears from the box. Dean says the image is there (I do see it below the box) and it's out of the way to enable you to add more images.
I think I hit done and then preview and I got nothing.
Ok. I tried it and it was a bit strange. Glad I read these posts.
Did do the text first. When I hit, "select a file to attach," it just kinda bullies its way into that square. It automatically wraps it up ... fortunately, the images are lined up at the bottom.
It will be interesting to see how to change or move the images.
Now this one would be great for a video.
I did a test of the click/drag attachment method you and others suggested (instead of using the select from file location box option I have been using) through the Attachment Manager.
Process does work for me, although I had to shrink down the forum screen size so I could see and click/drag the file I wanted from the stored directory window. You have to be able to see the file/source window to be able to use click/drag.
Dan
I give! As most know, I’m not the brightest bulb in the lot. Unless, I’m in the sun a the glare off of my head is very bright! I use the full editor, go to the attachments, chose and add a picture. The picture appears on the bottom of the attachment thingy. Then I hit done. The only thing I get is the picture link address. “Oh” I’m using a iPad! Jim
~ Jim Schmidt, Bucks County, PA 1953 Chevrolet 3804 1-ton In the DITY Gallery
Jim, iPad is what I use 99% of the time. Full editor, attachment manager, choose file. Click on photo, let it load, click done, click on post reply. Works every time.
Jim, iPad is what I use 99% of the time. Full editor, attachment manager, choose file. Click on photo, let it load, click done, click on post. Works every time.
Don’t forget to click on “Post Reply”!
It did work. Thanks for the spot. I need to adjust the image later for a "click for larger image" but I have to get in the server for that. A Monday do.
Is this an acceptable way to do it? [url=https://photos.app.goo.gl/96CvFt7wiAsmX4em7]Maybe????????[/url. It is for my old age, oops it is already here. And to hide the fact I cut out a bush.
Ron, The Computer Greek I love therefore I am. 1954 3100 Chevy truck In the Gallery 2017 Buick Encore See more pix 1960 MGA Roadster Sold 7/18/2017
You won!!! Link worked and picture looks great. Thanks for not giving up!
Next task, posting a picture "attachment" to your post (does not have to be posted on any picture storage web site).
Let us know when your ready. In the mean time, enjoy your success.
I would say when I get gray hair but it is too late for that. But some accuse me of tinting my hair, particularly my brother. He took after mom a skinny hillbilly who turned grey by 30 and I took after dad, a little on the chubby side and dark hair almost onto death.
Thanks, Peggy for misplaced confidence. I have tried it is like listening to a foreign language and not the anglo Saxon type. I just reread the instruction and I have been to that all along, I think.
I see some people have a video in with their Attachments and the video plays in the line up. This one by itself, presents itself as a download. It's a wmv file. Wonder if that is part of it??
Gonna try something else.
I have a 38 second video on my phone that is about 37 mb from crusin the coast. It seems to be to big to let me upload as an attachment and I can’t put it on my Flickr to link it because it’s video and not a photo? Any suggestions? 🤔🤔
I know this post has a different title. I wanted to keep the discussion in this testing spot until we can figure it all out.
Turns out, I can't delete this post. Sorry
Also the issue about video has been resolved (see further down). John says videos better off loaded to a hosting platform and then OP can link from there. ~~ Peggy
