Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (78buckshot), 176 guests, and 3 robots.
Topics128,274
Posts1,058,433
Members48,490
#1469377 10/03/2022 1:41 PM
Did the AD trucks originally leave the assembly line with a molded rubber boot that fits around the floor shift handle at the floor? I have a 4-speed in my 1948 Chevy 1/2 ton truck. Currently there is an after-market boot in place that is in bad shape. Is there a recommendation on where to buy a good quality replacement boot?
AD Addict & Tinkerer
Here is one from Classic Parts.
Phil
Project Journals
Stovebolt Gallery Forum
Sir Searchalot
Sir Searchalot
No boots back then.
Jim Carter , FL165 , $9.75 , fits in floormat opening and is covered by the floor mat around the shifter housing. Nope, no boots from factory, as bartamos says.
Ron - - Dusty53
1954 Chevy 3604
There's something I didn't know. My '52 has a parking brake boot under the floor (aftermarket of course) but I always assumed a boot was original. What did they use to seal those openings?
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
There are seals for both the shifter and the parking brake. The brake has a boot under the floor and the shifter has a seal mounted to the tranny cover.
Phil
Project Journals
Removed the after-market boot that was in bad shape. Can someone confirm that this area now displays as original? Thanks.
LUKE
Moderated by  ndkid275, Phak1
