4 members (Bills54, Nick in Manitou, Bill Hanlon, Stovebolt48), 73 guests, and 2 robots.
Topics128,035
Posts1,055,559
#1469481 10/04/2022 3:32 AM
Anyone know if the ‘38 “short” cab set on blocks and, if so, size and location? Anyone use hard rubber in place of wood? Thanks.
back yard wrench turner
Yes they do sit on blocks.
https://oldchevytrucks.com/cb206.html
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
They also have springs, spacers, and rubber mounting pads. The above link is for attaching the firewall to the cab, the wood allows a little movement. The below link is the actual mounting system. Don't mount it solid.
https://oldchevytrucks.com/cbk154.html
Joe H #1469515 10/04/2022 3:27 PM
Thank you!
Thanks!
Joe H #1469542 10/04/2022 6:59 PM
Joe,
First, I appreciate your help. I've gone on line to Jim Carter and called them. I also called Filling Station and Chevy of the 40s. As I understand there are the triangle wooden blocks that Wayne identified that buffer/connect the firewall to the cab. Do these blocks sit between the pieces of the cab/firewall, or between the bottom of the cab/firewall metal and the top of the frame?
I also looked at the cab mounting kit (CBK 154). From the "instructions" Jim Carter emailed to me, it identifies 8 bolts/ 4 sets; however it is not clear where the mounting points for each set are located. It also says you need two wood blocks (CB 247), but doesn't say where they go either.
If easier, you can email me at [email protected].
Thanks!!!
your bed will also have a set of wood blocks when you get that far. of course you could make them all, but if yours are like mine, (near non-existent) I don't have a good pattern to work off of...so I'll pay dearly for something actually rather simple.
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
37 GC #1469637 10/05/2022 2:38 AM
Larry
Agree. I already have them and the bolts from Chev of 40s. I believe there was a testical sacrificed in the transaction.
I will get under my truck Saturday morning and take some pictures of the cab mounts and bed mounts. My had been hacked up so the fuel tank area is not stock, but the mounting holes are still in the right place.
Here are some pictures of my '37 cab mounts. The first picture shows the mid cab mount and wood block under the door sill. You can also see the flange coming off the frame where the cab just sets on with rubber pads under it.
The second photo is the back of the cab and front of the bed mount. The cab should have a wood block, but I just made some wood pucks to put in place
The third picture is a close up of the front wood pieces.
Forth picture is mid bed mount.
Fifth picture is rear bed mount.
Sixth is the inside rear cab mount with spring. You can also see the seat belt mounted and an extra mounting hole I made not being used. All my electrical is also under the seat.
