2 members (Still At It, wilbur53), 130 guests, and 3 robots.
Topics128,196
Posts1,057,387
Members48,471
Will a 1957 8 lug Chevy truck rear end fit a 1950 Chevy 3600 Truck? Little or no modifications? This would solve a brake upgrade problem and get a taller gearset for this truck. Thanks in advance for anyone's advice!
There would be no gain on the gear set as both the 50 and 57 are 3/4 ton vehicles and would have a 4.57:1 rear axle ratio.
Could be a brake upgrade but you would likely have to relocate the spring mount pads on the later rear end to match the 50.
Fred
Thanks for the info, Fred. The '57 rear turns just over 4 revolutions, assuming 4.11. My '50 is definitely 4.57. I could easily move the spring mount pads. Do you know if the '57 is the same width as the "50? Or super close? I can't get to the '57 to measure it as it's a distance away. Thanks!
If you measure your 1950 tire tread centers and compare it to the 1957 62.25" center of tire tread to center of tire tread you'll have your answer...I don't have info on the AD trucks...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
You may have found something everyone is looking for. A 4.10 was an option in 67-72 3/4 ton trucks but not in a 57.
The center section may have been changed out using a later assembly. If so, go with it.
Fred
B Online: Content
That 4.10 will give you a 10% reduction in engine speed at any MPH and a 10% reduction in acceleration.
Thanks everyone for the info and input, I know where I'm headed now. I'll measure the "50 today. This Stovebolt community is the best.
It took Me 16-18 months,But I DID find a 4.10 Center Section for My "Eaton HO-72" Differential... They ARE out there, just gotta keep diggin around, and when I got [censored] or Aggravated NOT finding it, Just go back to the Garage, Crack Open an ICE COLD"Summer Shandy" and just Know that You'll find One, just didn't happen Today.... and Crank up the Radio in that Garage ,Too....
Jimmy Gatz
