4 members (Gdads51, Chris_Welch, texas46, 1 invisible), 144 guests, and 3 robots.
Topics128,267
Posts1,058,386
Members48,485
1950 Chevy 3100 216 3 Speed.
My tube radio refurbished and installed. The hole for the antenna was full because I want to go with a hidden antenna. Does someone have a recommendation for this. My first try of a hidden antenna seems to be a fail. I thought this would be easy. Thank you.
Darren
Current Project - 1950 3100 5 Window with a rebuilt 216 and 3 speed trans
Wasted my money on three different hidden antennas. I threw all of them away and drilled a hole to mount a real antenna.
Steve
1946 1/2 ton
Moderator, Electrical Bay
For decades people have put the the antenna under the vehicle...running horizontally and parallel to the ground. It will lose some long-distance power but it will work fine generally speaking and nobody will see it. In an automobile, your antenna works with one connection to ground (the frame) and one receptor pole. Back when AM radio was king, the antenna was much more critical, but with FM, an antenna can be pretty simple and still do a fine job. If a vertical antenna is important to you, you can also tuck one between the cab and the front of the bed so it doesn't show. The motorized hidden antennas were okay when they were made in the USA. Now they're pretty much junk. Good luck.
~ Jon
C Online: Content
OMG!! My truck would hate me if I got rid of my regular antenna. Where would Miss Hooters antenna girl reside?
Craig
O Online: Content
That's funny. Where did you get it?
1950 Chevrolet 3100 (Ol' Roy)
C Online: Content
From H00ters in Myrtle Beach, SC quite a few years ago while visiting a friend out there. Regarding hidden antennas, I like the idea of one between the bed and the cab. Maybe one horizontal under the bed might work, especially for us who rarely use our truck radios.
Craig
Moderated by  truckernix
