2 members (BC59, Pre '68 Dave),
148
Mod | | | Forums66 Topics128,089 Posts1,056,117 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 24 Junior Member | | Junior Member Joined: Apr 2006 Posts: 24 | I just got the 66 C60 dump running. And out of my wife's parking spot. So the pressure is off...I haven't pulled it off the truck yet, but, it looks like a crack in the left side of the exhaust manifold. The gaskets are bad and exhaust is leaking all around, so I can't really tell if the crack leaks too. Can a crack be stop drilled and brazed, or should I be looking for a replacement ?
Bill | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I have had some luck with stick welding exhaust manifolds using stainless rod. grind,weld,grind,repeat.It all depends on how much you are going to use the truck.Replacement sure is easier.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
