5 members (HandyAndy, klhansen, Hanks custodian, Hugh63c10, dt235sd), 78 guests, and 1 robot.
Topics128,092
Posts1,056,043
Members48,433
#146916 05/20/2006 1:08 AM
Junior Member
Junior Member
I just got the 66 C60 dump running. And out of my wife's parking spot. So the pressure is off...I haven't pulled it off the truck yet, but, it looks like a crack in the left side of the exhaust manifold. The gaskets are bad and exhaust is leaking all around, so I can't really tell if the crack leaks too.
Can a crack be stop drilled and brazed, or should I be looking for a replacement ?
#146917 05/20/2006 1:44 AM
I have had some luck with stick welding exhaust manifolds using stainless rod. grind,weld,grind,repeat.It all depends on how much you are going to use the truck.Replacement sure is easier.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
