2 members (BC59, Gray_Ghost), 154 guests, and 1 robot.
Topics128,079
Posts1,056,058
Members48,433
#1467091 09/18/2022 7:53 PM
I'm converting a 53 3100 to 12V. Does anyone sell a direct drop in replacement 12 blower motor? Or, does anyone sell a complete drop in replacement heater assembly?
Insomniac
Insomniac
I kept the 6V motor. It ran way too fast on 12 V, so I bought a voltage reducer.
Similar to this one: https://www.ebay.com/itm/141929142470
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Sir Searchalot
Sir Searchalot
You can buy all kinds of 12V fan motors. You search by motor diameter, shaft diameter, speeds and mounting bolt spacing. Give all your dimensions and we will find one for you. Be sure to use careful patient care when removing squirrel cage.
Or use a step down converter like Gord did....no disassembly/assembly work that way.
Ken,
You can also use the "Search the Site" tool displayed in the left page margin! Looks like the "picture" attached below.
Click the link, enter a few words (something like: 6volt to 12 volt heater motor conversion). Will provide you a list of previous thread links that include discussions on the topic desired. Many have done similar things before and you most likely will find part or source info to help you out.
~ Dan
1951 Chevy 3 window 3100
Ken Sungela You could go to NAPA buy voltage reducers 13$ mine has run since 2018 that way. Read the instructions takes 2 I think. Mine even has 2 speeds.
I put a 6-volt into my 12-volt truck and on high ran full blast on the medium it barely turned.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Several universal 12v hot rod heaters available through Amazon and Summit. I plan to use one in my 55e 3100.
DonBolt
1955.1 3100
235, 12v, 5-window, 5 speed
X
X Offline
I tried a voltage reducer but it didn't work well for me, so I went with a new 12v motor from Brother's Trucks (which is apparently now part of the Holley family) if I recall: https://www.holley.com/products/ac_and_heating/blower_motor/parts/HTRM063
It might have been Jim Carter Trucks: https://oldchevytrucks.com/el116.html
I think the shaft was smaller than the original so the new motor came with a sleeve to adapt it to the squirrel cage. Been working great for years.
1949 GMC FC253 - 1 Ton Dually
1966 Buick Wildcat Convertible
