3 members (JW51, tesa, Ponchogl), 49 guests, and 0 robots.
Topics128,076
Posts1,055,925
Members48,430
#146851 05/14/2006 6:21 AM
Junior Member
Junior Member
Was wanting to know if there is a way to convert from dual tires on the back to a single wide tire on the bigger trucks? Later batman
I like BIG trucks and I can not lie.
#146852 05/14/2006 10:14 PM
What about those big sprayer trucks farmers use or rent or whatever for fertilizer? If you can find a 10-bolt wheel in wide size, should be a doer. Army trucks had big tires, but those are bigger bolt pattern I'm sure. Anyway, what's wrong with duals? They look more Manly! HD3500 of modern design uses that bolt pattern, but center holes are diff size than 53 or older.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#146853 05/14/2006 11:24 PM
You will most likely have to buy either special wheels from a wheel manufacturer like Stockton Wheel (I don't recomend the company).
Or buy some wheel adaptors and then buy some wide singles often called super singels or wide base wheels for semi sized trucks.
Just my 1.5 cents.
1952 Chevrolet 3800 pickup
---All pictures---
#146854 05/15/2006 12:31 AM
Junior Member
Junior Member
Just asking may not even happen. I just like to be different I have always liked the look of a big tire filling up the wheel well or if you want to call it a pro street look even though its a bus i'd be doing it to. But who knows what I might do we'll see as things progress. Later batman
#146855 05/15/2006 12:42 AM
Those tire on the sprayer trucks are not intended
for street use and would likely give a poor ride.
I have seen the wide tires for the semis, Michelin makes them. They seem to be popular in
Europe and are just starting to appear in the US.
Bill Burmeister
#146856 05/15/2006 5:49 AM
Junior Member
Junior Member
Quote
Thanks LONGBOX55 thats what I would be looking for from Michelin if it would work.
#146857 05/15/2006 5:51 AM
A couple of tanker companies out here use 'em. I'm thinking they must either last longer,cost less per set,handle better or be cheaper/easier to repair and maintain-can't think of too many reasons to use 'em. As near as I can remember,those wheel adapters are about 800.00 per pair,the wheels will be another 5-600.00 a pair,and I don't know what the tires will run,but it's likely to cost a bit to get the set up you want. It'll sure look awesome when it's done though.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#146858 05/16/2006 12:50 AM
one of the reasons for going to the super single tires is to save weight therefore you can carry more payload. Drivers I've talked to generally like them. bigest complaint lack of traction on slick roads. seems tire companies are also suggesting better fuel economy.
#146859 05/16/2006 2:01 AM
All the reasons listed were the ones listed in an
article by Tire Review a few years ago. I seem to
recall that they were mostly testing in the western states.
batman, try www. michelinman.com for michelin
tire information.
Bill Burmeister
#146860 05/16/2006 2:35 AM
Junior Member
Junior Member
Quote
tire information.
Hey Bill thanks for the info I'll have to go look. And I see you are a fellow Illinoian and only a couple hours east of me maybe we'll have to get together sometime.Later batman
#146861 05/17/2006 12:55 AM
Hy, batman, I goofed. That website is for passenger and light trucks. I should have checked it first. However, www.michelintruck.com
has the information you need. I'm planning to hit some of the local show as my work schedule
allows and wiil be at Goodguys in Indy next month, maybe I'll see you there.
Bill Burmeister
#146862 05/17/2006 2:23 AM
Junior Member
Junior Member
Quote
Probably won't make goodguys but maybe you can tell me of some shows that are coming up that are here in IL.that you may go to. Later batman
