0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 19 Junior Member | | Junior Member Joined: May 2006 Posts: 19 | Was wanting to know if there is a way to convert from dual tires on the back to a single wide tire on the bigger trucks? Later batman
I like BIG trucks and I can not lie.
| | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | What about those big sprayer trucks farmers use or rent or whatever for fertilizer? If you can find a 10-bolt wheel in wide size, should be a doer. Army trucks had big tires, but those are bigger bolt pattern I'm sure. Anyway, what's wrong with duals? They look more Manly! HD3500 of modern design uses that bolt pattern, but center holes are diff size than 53 or older.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You will most likely have to buy either special wheels from a wheel manufacturer like Stockton Wheel (I don't recomend the company). Or buy some wheel adaptors and then buy some wide singles often called super singels or wide base wheels for semi sized trucks. Just my 1.5 cents. | | | | | Joined: May 2006 Posts: 19 Junior Member | | Junior Member Joined: May 2006 Posts: 19 | Just asking may not even happen. I just like to be different I have always liked the look of a big tire filling up the wheel well or if you want to call it a pro street look even though its a bus i'd be doing it to. But who knows what I might do we'll see as things progress. Later batman
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Those tire on the sprayer trucks are not intended for street use and would likely give a poor ride. I have seen the wide tires for the semis, Michelin makes them. They seem to be popular in Europe and are just starting to appear in the US.
Bill Burmeister | | | | | Joined: May 2006 Posts: 19 Junior Member | | Junior Member Joined: May 2006 Posts: 19 | Originally posted by LONGBOX55: Those tire on the sprayer trucks are not intended for street use and would likely give a poor ride. I have seen the wide tires for the semis, Michelin makes them. They seem to be popular in Europe and are just starting to appear in the US. Thanks LONGBOX55 thats what I would be looking for from Michelin if it would work.
| | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | A couple of tanker companies out here use 'em. I'm thinking they must either last longer,cost less per set,handle better or be cheaper/easier to repair and maintain-can't think of too many reasons to use 'em. As near as I can remember,those wheel adapters are about 800.00 per pair,the wheels will be another 5-600.00 a pair,and I don't know what the tires will run,but it's likely to cost a bit to get the set up you want. It'll sure look awesome when it's done though. Speed | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | one of the reasons for going to the super single tires is to save weight therefore you can carry more payload. Drivers I've talked to generally like them. bigest complaint lack of traction on slick roads. seems tire companies are also suggesting better fuel economy. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | All the reasons listed were the ones listed in an article by Tire Review a few years ago. I seem to recall that they were mostly testing in the western states. batman, try www. michelinman.com for michelin tire information.
Bill Burmeister | | | | | Joined: May 2006 Posts: 19 Junior Member | | Junior Member Joined: May 2006 Posts: 19 | Originally posted by LONGBOX55: All the reasons listed were the ones listed in an article by Tire Review a few years ago. I seem to recall that they were mostly testing in the western states. batman, try www. michelinman.com for michelin tire information. Hey Bill thanks for the info I'll have to go look. And I see you are a fellow Illinoian and only a couple hours east of me maybe we'll have to get together sometime.Later batman
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Hy, batman, I goofed. That website is for passenger and light trucks. I should have checked it first. However, www.michelintruck.com has the information you need. I'm planning to hit some of the local show as my work schedule allows and wiil be at Goodguys in Indy next month, maybe I'll see you there.
Bill Burmeister | | | | | Joined: May 2006 Posts: 19 Junior Member | | Junior Member Joined: May 2006 Posts: 19 | Originally posted by LONGBOX55: Hy, batman, I goofed. That website is for passenger and light trucks. I should have checked it first. However, www.michelintruck.com has the information you need. I'm planning to hit some of the local show as my work schedule allows and wiil be at Goodguys in Indy next month, maybe I'll see you there. Probably won't make goodguys but maybe you can tell me of some shows that are coming up that are here in IL.that you may go to. Later batman
