3 members (GIJOE298, Jaison, bucktruck), 76 guests, and 1 robot.
Topics128,154
Posts1,056,853
Members48,456
Never hurts to ask this group. But I’m assuming this is an obscure-enough topic that I may not get an answer….
Does anyone have a modern part number, and/or dimensions of the thrust bearing for a standard size king pin set? Speaking of the 47-53 truck here. Better still, anyone have one laying around they could just measure?
Or I suppose I could maybe even cross the original GM part number if anyone has that.
1951 3100
you'll need to be more specific, there's quite a difference between the kingpins on a half ton pickup and a 2 ton dump truck. what size rig do you have?
I’m sorry. 1/2 ton. Meant to put that in the original post. 1951 half ton.
1951 3100
JW51,
Lets see if I can help out. grin
Attached are pictures with basic measurements of a +10 oversize NOS bearing from a kit I have on hand. Kit was just one of many spare parts (boxes and boxes) that came with my '51 3100 when I got my Grandfathers' truck many years ago.
I did search for a modern number using the original GM# 373476, but could only find a scattered cross reference listing of about 5 manufacturers (and10 different part numbers). None of those show as available through any of the original manufacturers though. Did find an active number that kept popping up in searches through Napa (262-1296) but the on-line listing says "Not Vehicle Specific". Maybe possible to take my part to local Napa and see if they match???
Also noted that your location says Missouri. I am in the SE corner of KC metro area. Give me a shout if interested in meeting up to help wrangle this part need. thumbs_up
Worst case scenario, you can get a complete new king pin kit from one the many vendors that carry them.
Let us know if helpful.
Dan wave
~ Dan
1951 Chevy 3 window 3100
Try this one- - - - -the dimensions look right
www.ebay.com/itm/383898312008?
OOPS! the thickness is wrong. You would need to shorten the bottom of the spindle 1/8" to use that one, but it might be a good idea to do that since this is a commonly available industrial bearing and the listed load capacity for one bearing is greater that the gross weight of the whole truck.
Have you gotten an answer? I have two. I'll look at them when I get back to the shop.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
I ended up buying complete new set. Thanks, though.
1951 3100
